$30 shipped sound fair?
It almost looks like that lower arm has a little bit of a bow to it..? Before you blame the spindle, pull the hub off and look at the spindle dead on, the shaft should be perfectly square with the spindle itself, On my left side, mine was the opposite, it had negative camber, the shaft was bent up just a little, barely noticible until you got everything put back together..
That does look like it is bowed not sure maybe were seeing things.
it looks like the frame is tweeked where the front lower a arm mounts. could just be the angle of the pic though.
