muddripper14 Posted August 14, 2012 Report Posted August 14, 2012 my banshee only starts if i spray starting fluid in the carbs. it does the same thing hot and cold wont start with out starting fluid or a bump start. one it starts it runs great. i have cleaned the carbs and checked the reeds. could this be a pilot jet problem? Quote
bikerjon Posted August 14, 2012 Report Posted August 14, 2012 check your compresion x2 dont use starting fluid. Quote
muddripper14 Posted August 14, 2012 Author Report Posted August 14, 2012 just checked the compression and its just under 120 in both cylinders Quote
HolySheet Posted August 18, 2012 Report Posted August 18, 2012 Choke tube. Mine did the same thing. There is a small tube that connects both carbs. My money says that its not there if you are having this problem. Quote
