I really appreciate your help guys. I even bought carb rebuild kits hoping it was that. How hard is it to rebuild the top end?
if the cylinders are scorched then your going to have to take it to get the cylinders bored over then your gonna have to buy some pistons and rings and install them.... look up jlsparky7 on youtube he has very good videos showing how to do a top end rebuild
Fuel, spark, compression, need all three to work, check all three and eliminate them...
And as far as top end goes its very simple, but I'd recommend sending your cylinders to a site sponsor to be bored, might as well be ported too, then get a rebuild kit (from the same builder) and install... Then do a leakdown, compression test, rejet and zoom
maybe floats stuck....or huge jets .do a comp check like mentioned , dry the pipes out and kick it with no plugs in to get any xtra gas out of the topend. hopfully your bottem end isnt full that could cause hydro lock,then try clean+set up carbs to your mods+ fresh plugs+ check spark and try to start it ...goodluck
Edited by shakar
  • 1 year later...
The OP hasn't been on in over a year. I'm sure he either figured it out or sold it.
but it could help future members who have this issue and use the search function.
  • Like 1
