kenny007
Everything posted by kenny007
  1. Just wanted to say thank you to hoppedupandcountdown and every on else who helped but he hit the nail on the head. I mixed up the slides it back to normal thank you guys.
  2. I didnt think the slides didnt matter arent they the same? Im not sure if I switched them around or not I didnt think it would make a difference.
  3. Yea I didint touch anything there, but I got to idle now but when I accelerate it stutters do you think it might be the spark plugs?
  4. no nothing out of the overflow tubes when its off only a little when its running. Yea only change is the frame. what should I look for on the carb tops?
  5. can anyone else chime in please.
  6. The airbox is the same. what wire could of i possibly crossed?
  7. Ok guys I tried searching on here but couldnt find what I needed. so here goes. I swapped frames, before the swap the engine ran fine. now to turn it on i have to open the throttle all the way. It starts pretty quick but if i let go the throttle completely it shuts off. When I accelerate it it bogs out. So I closed the fuel valve and when the fuel started to run out it sounded perfect. so i opened the valve again and it went back to boging out almost as if its flooding. It has the tors eliminated, circuit pro pipes and as far as I know carbs and everything else is stock. if i have to adjust any screw please let me know how and which ones because i am a rookie at this. Any help will be greatly appreciated. Thankyou.
  8. Does the swing arm come with the shaft? How much you want for it?
  9. well the positive side of this is that now you know that your banshee really pissed someone off. You must be doing something right.
  10. I appreciate it guys. Nice bike zillafreak. What's the name of that color?
  11. wow! that looks sick nice job. Yeah Im the chicago area. Not sure if I want to go with a jet black but now I see zillafreak's bike and Im having second thoughts. Zillafreak is the bike completed and put back together, do you have a pic?
  12. what is the average cost of getting a frame powder coated?
  13. kenny007
    Frame
    Thanks I got one.
  14. Ok I found a frame, the guy has the certificate of origin from the original owner which came from the yamaha dealer is that all Ill need to title it in illinois?
  15. is a certificate of origin from a yamaha dealer all i need to title a banshee?
  16. Cool thankyou
  17. Is there any difference between a 97 and 98 frame?
  18. kenny007
    Frame
    Im looking for a completely stock frame with a clean title and visible vin# on frame. Let me know what you guys have.
  19. It looks like it was sanded off. I think the guy tried to get powered coating off and went a lil too deep, I hope.
  20. So i just noticed the vin on the banshee I bought is gone. That number cant be found anywhere else on the banshee? Nothing can be done? what i have is a Wisconsin Department of Natural Resources atv renewal registration application with the vin on it.
  21. Would you be able to make a speedy gonzales.
  22. Lol blueragracer! I would have never though that would be the problem, well I thank God it was that and nothing major.
  23. I just got the banshee about two weeks ago and its my first atv. so i thought the power it was making was normal then I noticed it leaking fuel from the right exhaust and barely any compression. Someone told me it was a stuck float so i ordered carb rebuild kits. Today I was gonna try and rebuild the carbs but I decided to look down into the carbs and check the slides first, and there it was a shop towel stuck in the carb. I removed it and now I really know how much power these things make. Wow. Im loving it.
  24. Oops! I didnt mean to put this thread here. I dont know how to move dont know if Im allowed to even move it. Sorry it was an accident.
  25. What section should i put this under? Well heres the pic. Its was a shop towel stuck in the carb. http://i1060.photobucket.com/albums/t454/kennyg2083/mailgooglecom.jpg
