ITFD Posted June 30, 2012 Report Posted June 30, 2012 I need to remone the emultion tubes or needle jets better known as. Has anyone ever done this? I'm not sure if they press in or screw in. The reason is my bike sat for 5-6 years with gas in it. The bowls were full of varnish . I've cleaned everything good but I think the air holes in the emulsion tube are still plugged. This is whats causing my rich running midrange. Thanx Quote
mailman Posted July 1, 2012 Report Posted July 1, 2012 It might help if you gave more info. like what carbs you are talking about. Some carbs the tube isn't meant to come out and some it is. Quote
moledigger Posted July 1, 2012 Report Posted July 1, 2012 If they are stock carbs they just push out the top where the slide goes. Quote
ITFD Posted July 7, 2012 Author Report Posted July 7, 2012 Than. Had to clean emup. Yhey were both completely varnished up. Quote
