locogato11283 Posted June 10, 2012 Report Posted June 10, 2012 I just decided to upgrade from the LSR to the JJ&A on my Banshee. I thought I'd do a weight comparison between the two. This is the axles, carriers, sprocket hub, brake hub and wheel hubs. JJ&A LSR Quote
rjdgriff Posted June 10, 2012 Report Posted June 10, 2012 I just decided to upgrade from the LSR to the JJ&A on my Banshee. I thought I'd do a weight comparison between the two. This is the axles, carriers, sprocket hub, brake hub and wheel hubs. JJ&A LSR ill get a weight on my durablu axle and see how heavy it is and post on here sometime soon Quote
springer Posted June 11, 2012 Report Posted June 11, 2012 i weighed the difference from when i went from a stock axle setup to my fireball (jj&a) setup. can't remember the weight, but i remember it was huge. Quote
locogato11283 Posted June 11, 2012 Author Report Posted June 11, 2012 i weighed the difference from when i went from a stock axle setup to my fireball (jj&a) setup. can't remember the weight, but i remember it was huge. I knew the LSR was heavier, but I didn't know to the tune of almost 10 pounds! That's a TON of rotating mass. I'm fucking pumped! Quote
BigRed350x Posted June 11, 2012 Report Posted June 11, 2012 Is that one of the gun-drilled JJ&A's or is it the solid 34" play axle? - Jared Quote
locogato11283 Posted June 11, 2012 Author Report Posted June 11, 2012 Is that one of the gun-drilled JJ&A's or is it the solid 34" play axle? - Jared It's a 34" solid play axle. I didn't wanna push my luck. Quote
wacko2000 Posted June 11, 2012 Report Posted June 11, 2012 Damm bro 10lb difference is insane!! Quote
NickisGod Posted June 11, 2012 Report Posted June 11, 2012 Just wondering, is the j&j axle all aliumium? This could explain the 10lbs difference. Quote
Hilarious Posted June 11, 2012 Report Posted June 11, 2012 Just wondering, is the j&j axle all aliumium? This could explain the 10lbs difference. yes Quote
Sweet1 Posted June 11, 2012 Report Posted June 11, 2012 Any idea what the whole stock settup wieghts? 10 pounds is alot jeez.. Quote
locogato11283 Posted June 11, 2012 Author Report Posted June 11, 2012 Damm bro 10lb difference is insane!! I know. I was shocked. I thought a few pounds, but not 10. Just wondering, is the j&j axle all aliumium? This could explain the 10lbs difference. Yes, it's all aluminum. Very nice stuff. Any idea what the whole stock settup wieghts? 10 pounds is alot jeez.. No idea. It has to be quite a bit too. Probably comparable to the LSR setup. Quote
m671054 Posted June 12, 2012 Report Posted June 12, 2012 I thought to drilled axle was actually stronger. Check jj&a web site i might be wrong Quote
rubberneck Posted June 12, 2012 Report Posted June 12, 2012 That lsr axle is steel right? I have an older lsr aluminum axle setup, i should weigh it and see what that set up weighs Quote
springer Posted June 12, 2012 Report Posted June 12, 2012 i may be wrong since it was so long ago, but i think i remember something like 15-16 lb difference for a stock setup to my drag axle setup. Quote
