when you rebuilt it... did you use sealant to seal the rubber plugs at the bottom of the cylinders?
my first time rebuilding mine... I didnt use sealant on them and I had coolent in my cases.
No but I dont have any coolant in the case just in the cylinders.
no the plugs on the bottom too but like i said if its in your cyl is in your crank side of the cases
Well I just ordered a new head gasket and I will change the oil. Is that all I need to do to get the coolant out of the crank side? Do you guys think oem gaskets are better than aftermarket?
