I just rebuilt my carbs . I put in a new rebuild kit and new floats. I set the carb float level to 21mm and it leaks fuel out of the bottom overflow if I shake the bike real hard or when I am riding. Anyone have any suggestions ? Thanks.
Why does it not make sense? That's what they are called. If you don't have a clue don't respond to the post. The rubber plugs are called cylinder seals. I was just looking for a little help. Thanks.
Thanks for the the replies guys. Just not sure what I need to do to get the coolant out of the crankcase. Do I have to split the case? I really need to buy a clymers for it.
Well I just ordered a new head gasket and I will change the oil. Is that all I need to do to get the coolant out of the crank side? Do you guys think oem gaskets are better than aftermarket?
Thanks for the quick response. I just rebuilt it and had a fresh head gasket on it. Thats why I was wondering if it could come from somewhere else. I have the head off now going to see if it is warped.
I have coolant getting into my cylinders. I was wondering if a bad head gasket could be the only way it was coming in? Or could it come in from some other spot. Thanks
