Im looking at buying a head in the next few weeks and am trolling for any and all info i can find.So far from searching here and comparing my mods to others i need 21cc domes at 700ft elevation with T5's,chariot reeds,and k&n with +3 timing.But ive not seen much on having to rejet.
Right now my bikes perfectly jetted and running like a scalded dog will bolting on a head change my jetting needs?
Also at 700ft can i or should i run smaller domes?
Id like to be able to use the fuel we have local here which is 89 but i can travel 20 miles for 93.
What is your compression at? Normally you do not need to rejet with just the addition of a head/smaller domes......however it can/will change your compression and fuel requirements. To be honest....I wouldn't think of running anything over stock compression on anything less than 93
Compression is 125psi in each cylinder i run anywhere from 89-93 in it now.
From what i gather on here 21cc domes give around 30psi more of compression will i need to run on 93 at 155psi?
Very much so yes. You will definitely need to be using 93 t that point
