Lighting
  • 3 weeks later...
I just put some 35w bulbs on and they are dim unless y
ou run only one bulb. The box says 75w on it as well so I'm thinking that may be to much.
I'm wondering if it has something to do with I have a 87 and the bulbs are for a newer machine.
Below is the link to the bulbs I got
URL: http://pages.ebay.com/link/?nav=item.view&id=270954377814
ALL Banshees take the same light bulbs in the headlights! All years have the same output stators stock. You should be able to run 2 35 watt bulbs no problem, if the box says 75w on it then I think you have 2 75 watt bulbs, not 2 35 watt bulbs.
On the Ebay add it stated that they were 35W but on the packaging it says 35/35W up 75/75w, the bulb it self just says 12v 35/35w so I'm a little confused
The 75w rating is the comparable halogen light output. Meaning, it's a 35w xenon bulb equivalent to a 75w halogen bulb. It only draws 35w. You got the right ones.
