Uf21 Posted May 6, 2012 Report Posted May 6, 2012 I know plug chop is better but since I cant really do plug chops cause I dont have anywhere nearby to take it for a quick ride, I was wondering how good the choke trick works for getting jetting right VS the plug chop? Quote
Larry's Shee Posted May 6, 2012 Report Posted May 6, 2012 http://www.nitrousexpress.com/product-details.php?id=1440 http://www.autozone.com/autozone/accessories/COMP-Cams-Pro-spark-plug-viewer-magnified-flashlight/_/N-26ew?itemIdentifier=214646_0_0_ Consider getting something like these. Take a bunch of jets and plugs. Do a plug chop without cutting the plugs off. Will be doing a plug "reading" Quote
Uf21 Posted May 6, 2012 Author Report Posted May 6, 2012 http://www.nitrousexpress.com/product-details.php?id=1440 http://www.autozone.com/autozone/accessories/COMP-Cams-Pro-spark-plug-viewer-magnified-flashlight/_/N-26ew?itemIdentifier=214646_0_0_ Consider getting something like these. Take a bunch of jets and plugs. Do a plug chop without cutting the plugs off. Will be doing a plug "reading" I think you kind of missed the point lol. I cant do a plug chop because to do a plug chop I need to ride it and WOT till sixth gear. I cant do that since I live in the city and there is nowhere nearby where I can do that. Quote
ClayAiken Posted May 6, 2012 Report Posted May 6, 2012 http://www.nitrousexpress.com/product-details.php?id=1440 http://www.autozone.com/autozone/accessories/COMP-Cams-Pro-spark-plug-viewer-magnified-flashlight/_/N-26ew?itemIdentifier=214646_0_0_ Consider getting something like these. Take a bunch of jets and plugs. Do a plug chop without cutting the plugs off. Will be doing a plug "reading" Damn those are expensive when you can buy a 10$ hacksaw and your time. Quote
252wheelieking Posted May 6, 2012 Report Posted May 6, 2012 (edited) the choke trick only really help to dail in your pilot jet. The plug chop is to dail in your main jet. So no you can not do the choke trick to fully dail your jetting in. you have to ride the bike to dail in your needle & main jet. Edited May 6, 2012 by 252wheelieking Quote
locogato11283 Posted May 6, 2012 Report Posted May 6, 2012 It would be much simpler to post your whole set up and let us help you figure out what to run. Chances are there is someone here running something similar to you. Quote
bluebanshee98 Posted May 6, 2012 Report Posted May 6, 2012 I think you kind of missed the point lol. I cant do a plug chop because to do a plug chop I need to ride it and WOT till sixth gear. I cant do that since I live in the city and there is nowhere nearby where I can do that. is there a spot where you can get to 4th wot? i have done plug chops in 4th. try to keep it pinned in 4th as long as you can, then kill it. turn quad around start it back up and do it again (4th wot then kill it) take plugs out and replace with the old ones and ride home. well like i said thats if you have the space to get to 4th.... Damn those are expensive when you can buy a 10$ hacksaw and your time. i used to use the hacksaw and yes it works. if you have a dremel i would suggest using that. alot easier! makes cutting the threads a breeze Quote
Uf21 Posted May 6, 2012 Author Report Posted May 6, 2012 is there a spot where you can get to 4th wot? i have done plug chops in 4th. try to keep it pinned in 4th as long as you can, then kill it. turn quad around start it back up and do it again (4th wot then kill it) take plugs out and replace with the old ones and ride home. well like i said thats if you have the space to get to 4th.... Yes there is place where I can take it to 4th though something else I just thought about. Where I live is nearly sea level and where I ride is 3500-4000ft above sea level. If I jet it near home it won't be right jetting, right? Quote
Uf21 Posted May 6, 2012 Author Report Posted May 6, 2012 It would be much simpler to post your whole set up and let us help you figure out what to run. Chances are there is someone here running something similar to you. Well my planned mods are. DMC 916 (already on), pro flow foam filter and no snorkel with lid on but holes drilled through it. My elevation is 3500-4000ft and temps are around 50-70F Quote
