have a banshee with 4 ml stroker with 115 long rods ,set of 795 pistons, stock cylinders and im wondering what cool head will work as a replacement for shaved stock head ,i run 112 sunoco and 93 mixed 1 to1 amesoil dominator,has thick spacer head gasket
Edited by meanmossberg
Any coolhead will work, but you will need 4mill cut domes in order to run the 4mill crank.
ok so in looking at a trinty or noss head ill have to check into the cut domes,,what size domes for half and half race gas????
DO NOT buy a Trinity head, they are made to only accept trinity domes as well as trinity head bolts. Get a NOSS, Pro-Design, or Chariot Head they all use the same domes. I recommend you call Jeff at FAST Racing he will set you up with a head as well as 4mill cut domes.
For the custom cut domes give Kevin @ HJR a call. He can get you a set of domes cut for the 4mil. Ditch the spacer plate and go with the cut domes.
- Jared
I run RK Tek's Torqueline Coolhead with custom domes machined by them, domes were machined specifically to my engines specs.
http://www.2strokeheads.com/
thanks for posting that site....was wondering where i could domes for that head @.
