willnegus Posted May 3, 2012 Report Posted May 3, 2012 i need to bore my stock jugs that have been ported by hjr to 66.5, but wiseco does'nt list past 66mm, is there anyone else that makes pistons above 66 mm for a 4 mill Quote
BigRed350x Posted May 3, 2012 Report Posted May 3, 2012 Send them to millenium and they can plate them for you. Quote
shanYE west Posted May 4, 2012 Report Posted May 4, 2012 as long as your using a long rod crank, WSM makes a 66.5 forged long rod piston. Or, if your stuck on wiseco, 573MO6650 but.. you'll have to get new domes or have the head rechambered. If its a setup your looking to keep for a while.. then plating or re sleeve would be the other options. Quote
willnegus Posted May 4, 2012 Author Report Posted May 4, 2012 as long as your using a long rod crank, WSM makes a 66.5 forged long rod piston. Or, if your stuck on wiseco, 573MO6650 but.. you'll have to get new domes or have the head rechambered. If its a setup your looking to keep for a while.. then plating or re sleeve would be the other options. kevin already cut my domes, so do i need them cut out more with the 573MO6650 Quote
willnegus Posted May 4, 2012 Author Report Posted May 4, 2012 Send them to millenium and they can plate them for you. can you send me a link for millenium, might be interested in plating, i want to keep these jugs because it is a trail bike. kevin did an awsome job not a 2 stroke or 4 stroke around here can touch it. i live in nb canada Quote
shanYE west Posted May 4, 2012 Report Posted May 4, 2012 kevin already cut my domes, so do i need them cut out more with the 573MO6650 the dome angle needs to be corrected for the blaster piston. plating the cylinder is going to cost about 300-350 for the set. http://mt-llc.com/ Quote
willnegus Posted May 4, 2012 Author Report Posted May 4, 2012 the dome angle needs to be corrected for the blaster piston. plating the cylinder is going to cost about 300-350 for the set. http://mt-llc.com/ thanks man Quote
willnegus Posted May 4, 2012 Author Report Posted May 4, 2012 thanks man will it work as good with the blaster pistons and the big bore blaster domes Quote
