willnegus
Everything posted by willnegus
66 mm stock jugs can they be bored bigger?
willnegus replied to willnegus's topic in Banshee Repairs and Mods
will it work as good with the blaster pistons and the big bore blaster domes -
thanks man -
can you send me a link for millenium, might be interested in plating, i want to keep these jugs because it is a trail bike. kevin did an awsome job not a 2 stroke or 4 stroke around here can touch it. i live in nb canada -
kevin already cut my domes, so do i need them cut out more with the 573MO6650 -
i need to bore my stock jugs that have been ported by hjr to 66.5, but wiseco does'nt list past 66mm, is there anyone else that makes pistons above 66 mm for a 4 mill
can someone tell me if i have quite a bit lower compression on one cylinder if it will make my engine try and run wide open after i give it a rev, i did a leak down test and passed. slides ar'nt sticking,this is what i did, i rebuilt the top end and took it for a rip for about an hour, then realized that i overheated it bigtime and melted a piston, because i ripped the oring that is inside the clutch cover, it put all the coolant inside the tranny and nothing in my engine. so i tore the cylinders off honed out the bad one switched the good piston over in the other hole that i just honed, and took the old piston that had lower compression, put it in the other hole wich was the side that did'nt blow up. stumped and when the engine is screaming out of controll the slides are in the idle position
Billet & more billet
willnegus replied to PACIFIC NW BANSHEE's topic in For Sale - Parts & Accessories
do you hve the clutch cover and flywheel cover -
Drag Banshee part ouy lots of chrome jj&a LSR K&T Parts
willnegus replied to Te-Yez's topic in For Sale - Parts & Accessories
do you have the clutch and stator covers -
pipes,carbs,a arms.spindles,hubs, misc
willnegus replied to smokin 2 stroke's topic in For Sale - Parts & Accessories
do you still have the a arms, i need a left caliper, and a right spindle, clutch cable and lever, handle bars -
do you still have your a arms and how much?, my email is [email protected] -
when i turn my lights on my engine dies, please help
would i be safe adjusting my timing and how much, here is what i got, 01 shee, .50 over wisecos, 21 cc noss head fmf fattys, k&n no lid, 300 jets, stock carbs. i just run pump gas
wont run with lights on,, but will with them off
01 -
no -
wont rev out -
rm stator rm flywheel rm hp cdi, are they any good
ok thanks man -
ok thanks, does yours heat up when your trail riding, would it be a good idea to get a temp guage
ok i have a 01 woods beater shee .50 over wiseco's 21 cc nossmachine head, fatty's powercore 2's, 300 mains, k&n no lid, what size pilots should i be running?
need stator and maybe a cdi for an 01,,, need it quick to nb canada, i have paypal
do you still have that stator for the 02 and will it fit my 01 and how much total for paypal i live in nb canada
does anyone rewind your own stator, i just finished rewinding mine it took 9 hours, not sure if it worked because it still wont start, the reason i rewound it is because i broke the original windings, so i rewound it myself, is it even possible for it to work
did you rewind your own stator, i just finished rewinding mine it took 9 hours, not sure if it worked because it still wont start, the reason i rewound it is because i broke the original windings, so i reound it myself, is it even possible for it to work
