bryan b Posted April 11, 2012 Report Share Posted April 11, 2012 Lookinga at buying a cool head and was wondering if one brand was better th.an the other? Also what dome sizes can you run and still be on pump gas? Im putting out 125psi curently with factory head. Bike if for trail/dune riding. Has fmf fatty pipes, k&n single air filter with factory air box and no lid. 300 main jets with 27.5 pilots. Stock carbs. Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted April 11, 2012 Report Share Posted April 11, 2012 My dads selling my trinity coolhead. Its chrome. Its 150$ free shipping. 20cc domes that should put u arpund 150psi if im not wrong. But mine comes with all u need to install. Acorn nuts, 20cc domes and brand new o ring kit. Let me know i can link you Quote Link to comment Share on other sites More sharing options...
bryan b Posted April 11, 2012 Author Report Share Posted April 11, 2012 My dads selling my trinity coolhead. Its chrome. Its 150$ free shipping. 20cc domes that should put u arpund 150psi if im not wrong. But mine comes with all u need to install. Acorn nuts, 20cc domes and brand new o ring kit. Let me know i can link you Send me a pm. And do you have to have longer head studs for the trinity cool head? Quote Link to comment Share on other sites More sharing options...
andrew3160 Posted April 11, 2012 Report Share Posted April 11, 2012 I prefer the the Noss head my self. I'm running 21cc domes on 91 at about 900-1000 ft above sea level. 20cc domes would be fine too. Quote Link to comment Share on other sites More sharing options...
bryan b Posted April 11, 2012 Author Report Share Posted April 11, 2012 so 20cc domes would be good for pump gas. What the limit per say on compression for 91 octane? Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted April 11, 2012 Report Share Posted April 11, 2012 Whats your elivation? Quote Link to comment Share on other sites More sharing options...
Nightmare Posted April 11, 2012 Report Share Posted April 11, 2012 so 20cc domes would be good for pump gas. What the limit per say on compression for 91 octane? 160-165 is the limit Quote Link to comment Share on other sites More sharing options...
bryan b Posted April 11, 2012 Author Report Share Posted April 11, 2012 (edited) Whats your elivation? 798ft is elevation.....................what all factors in other than elevation and cc size of the dome? Edited April 11, 2012 by bryan b Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted April 11, 2012 Report Share Posted April 11, 2012 Oil brand. Mixing ratio Octane. timing. Quote Link to comment Share on other sites More sharing options...
bryan b Posted April 11, 2012 Author Report Share Posted April 11, 2012 (edited) factors for what? to what gas to use? dome size and shape are important pipes, porting, compression, timing, AFR, temp, lots of things matter. i asked earlier about what the per say limit is on compression for pump gas and you replied there are alot of factors there. i have fmf gold series fattys, no porting, 125 psi currently , 32:1 mix with belray synthetic, afr screws are out 2 turns, elevation is 798 ft, +4 timing. just trying to see how small a dome i can get and run pump gas. Edited April 11, 2012 by bryan b Quote Link to comment Share on other sites More sharing options...
bryan b Posted April 11, 2012 Author Report Share Posted April 11, 2012 like i said before, call up brandon at wildcard, 435-623-0148 he will get you some custom domes that will be better than shelve and should run great on pump. you will need to tell him everything you can about your engine. 10-4 thanks Quote Link to comment Share on other sites More sharing options...
Chip M Posted April 11, 2012 Report Share Posted April 11, 2012 so 20cc domes would be good for pump gas. What the limit per say on compression for 91 octane? My mods are very similar to yours except my elevation is 0- 50 feet A.S.L. I have the Pro Design Cool Head with 19's. It has my compression up to about 165. Too high. Brandon told me to go with the 22's and it would put me about where I should be. That is only a place to start, but a safe place. All bikes are going to be a little different and as you have heard the engine set up,mods, tuning, fuel and elevation all will change the end result. I can tell you for sure that although mine will run on 93 octane, I found that the 100 octane pump race fuel I get from Sunoco runs much better and no ping. I was told that running the 93 octane with 165 compression is border line at best and would probably cause a detonation problem. 155 is said to be a high safe zone. Good luck and for sure call Brandon. Quote Link to comment Share on other sites More sharing options...
06bluebanshee Posted April 11, 2012 Report Share Posted April 11, 2012 (edited) Get a Noss head......... 21 domes will put you at 152 psi. 20's would be pushing it on pump gas. 21's are good and safe for sure Edited April 11, 2012 by 06bluebanshee 1 Quote Link to comment Share on other sites More sharing options...
firebanshee Posted April 12, 2012 Report Share Posted April 12, 2012 I would not use trinity domes at all. I had a trinity head once and kept blowing o rings and rattling plugs loose, switched to a Noss head and domes with the same cc of dome and problem went away. 21cc dome at sea level with +4 on the timing is safe for pump gas. Quote Link to comment Share on other sites More sharing options...
pcplatinum21 Posted November 15, 2012 Report Share Posted November 15, 2012 can you run 20cc domes on a .75mm over banshee with v-force 3 reeds and pc pipes on pump gas and be fine..about 800ft above sea level? Quote Link to comment Share on other sites More sharing options...
