Sounds like your float is sticking. I'd try taking the bowl off and cleaning it out, make sure the float is moving freely.
yup the float is sticking. clean the carb
Banshee Carb Cleaning and Rebuild Mikuni look here on youtbe
Edited by toytech
No Link?
My carbs are leaking too.
I was told to use a q-tip and toothpaste to polish the float needle seat.
Edited by Strm Trpr
No Link?
I checked my floats and cleaned my needle valves. It's still leaking!! It has a slow drip coming from both carbs.... WTF :angry:
This was discussed a while back about the cleaning your needle seat and float needle with toothpaste. Here it is.
http://www.blasterforum.com/do-yourself-20/easy-almost-free-way-stop-leaky-carbs-33335/
could be dirt in the needle seat or floats need adjusted.. also if it sits long periods of time with the new ethanonol gas it actually eats the rubber and seal in the carbs use a Star brite Star Tron Enzyme Fuel Treatment Gas Additive
