KarTek Posted March 18, 2012 Report Posted March 18, 2012 Guys, the choke knob just won't stay out any more and it's a little difficult to kick the engine and hold the knob out at the same time. So, is there a way to adjust the friction or is it just shot and needs replacement? Any tricks to make it work? Thanks! Quote
Jereme6655 Posted March 18, 2012 Report Posted March 18, 2012 Replace. I know Jeff carries good used ones for cheaper prices....l.but as far as I know I've never heard of anyone being able to fix the choke knob Quote
Glenyboy Posted March 18, 2012 Report Posted March 18, 2012 I'm sure I see a YouTube video before on how to take it apart and maybe fix it, as mentioned above its easy to change, I just bought a new one off of eBay. Quote
ClayAiken Posted March 18, 2012 Report Posted March 18, 2012 Jeff at Fast carries them. I just hold mine. Quote
Overboost Posted March 21, 2012 Report Posted March 21, 2012 replace stock carbs with some PWK's works every time Quote
Boone Posted March 23, 2012 Report Posted March 23, 2012 I took mine apart. Pulled the little clip off. Used a hacksaw blade to "re-cut" the groove's on the shaft so they have nice sharp edges again instead of all rounded due to years of use. compress the snap ring a little for a tighter fit into the grooves and re-installed. Works better than new... No bullshit. Otherwise.. you could always just use a twig broken off about 3/4" long and prop the knob out... Quote
BANSHEE HP Posted March 24, 2012 Report Posted March 24, 2012 I took mine apart. Pulled the little clip off. Used a hacksaw blade to "re-cut" the groove's on the shaft so they have nice sharp edges again instead of all rounded due to years of use. compress the snap ring a little for a tighter fit into the grooves and re-installed. Works better than new... No bullshit. Otherwise.. you could always just use a twig broken off about 3/4" long and prop the knob out... repair,i wouldnt use a hack saw but.... take the choke out, there will be 2 notches on the choke shaft, they get rounded off, get a small file and touch them up. Quote
AKheathen Posted March 25, 2012 Report Posted March 25, 2012 really?......?.......?.... yah, rounded, is fine..... the clip gets worn out. 90% of the time, that is what it is every time you can pull the worn-down clip and try to make a new one, a micro-torch is essential to get it bent reliably. the clip is located under the rubber boot, and resembles a door window crank handle clip in your car. really, though, if you don't find a brand new choke assy in the $8-14 range, you are doing wrong. Quote
