UPbansheeRacer Posted January 29, 2012 Report Posted January 29, 2012 what kind of spark plugs do you guys like to run? im using ngk but any other suggestions? Quote
okbeast Posted January 29, 2012 Report Posted January 29, 2012 B8ES for gas, B9EGV for alky. You're overpaying for anything else IMO Quote
NetBSD Posted January 29, 2012 Report Posted January 29, 2012 NGK here, use them in every bike i own Quote
jbooker82 Posted January 29, 2012 Report Posted January 29, 2012 I usually run NGK BR8EIX's ( or what ever the Iridium Plugs are). Same heat range as stock as well. I have also run NGK BPR8ES's they are the same heat range as stock but they have a Projected tip that hangs down a little in to the combution chamber. That way they are not recessed in to the head. Quote
