EvilBanshee Posted December 8, 2011 Report Posted December 8, 2011 Hey guys, curious to what it takes and if its WORTH putting a banshee on ALcohol? My current Set up is a " Vito's 421 (68mm bore, +4mm stroker crank) with 22 CC domes running 104 octane. 34mm PJ carbs. NOw i only have fmf Fatties on it at the moment, (will be shearers soon) What does it take ? And will my engine hold up? I dont drive the thing hardly so i dont care if its a pig on fuel. I want this thing stupid Fast. But i dont want to have to rebuild it every 10 hours either lol. Give me the details of whats allll needed to switch over? Quote
Dicklez Posted December 8, 2011 Report Posted December 8, 2011 IF your in canada and ride in the snow and in the cold I think your wasting your time. Quote
EvilBanshee Posted December 8, 2011 Author Report Posted December 8, 2011 IF your in canada and ride in the snow and in the cold I think your wasting your time. LOL im 1 hour from detroit. IT snows only december- marchish. Other wise we have great warm weather up here. I dont ride my Shee in the snow. Thats why i have a snowmobile lol Quote
EvilBanshee Posted December 9, 2011 Author Report Posted December 9, 2011 No Body got nothing? LOL I know ill have to put in like 17cc domes or somthing? and double my jet size. But can i run my standard fuel lines and stuff?? Quote
lms1977 Posted December 9, 2011 Report Posted December 9, 2011 I'm pretty sure your carbs will need work done to them to work right the emulsion tube has to be modified I think and probably need oversized bowls maybe a fuel pump not sure thou Quote
Jereme6655 Posted December 9, 2011 Report Posted December 9, 2011 lms is right.....gotta have your carbs set up for alchy....OR you could buy a different set of carbs already for alchy.....then its just a switch to run gas. You'll also need to modify your fuel cap as it will then start to cause fuel flow issues because it will basically pull your tank under a vacuum......not a large enough hole to let in air fast enough to the tank. also you need to look into how available alchy is in your area. And if you want it to last your going to have to purge the bike everytime you ride it..... Quote
fastbanshee8 Posted December 11, 2011 Report Posted December 11, 2011 Alcohol attracts water, and it's also hard on fuel lines, and o-rings, so it can't be left in the carbs/motor. Quote
jbooker82 Posted December 11, 2011 Report Posted December 11, 2011 Purging flushes the methanol out of the carbs and engine. If you leave methanol in side the carbs and motor it will corode the aluminum and steel. The aluminum will start to form a white scale. Kind of like aluminum wheels that have a wheel weight. You have to have the carbs setup for methaol. It takes 2x as much methanol than gasoline. So your carbs have to be able to flow double the fuel. This also means your fuel milage is going to be cut in half. More than likely it will end up less than half because your normaly run methanol pretty rich. Quote
Jereme6655 Posted December 11, 2011 Report Posted December 11, 2011 and also.....methanol doesn't make more power.....its more stable....meaning you can run more COMPRESSION to MAKE more power while keeping the chances of detonation lower. This allows you to throw more power out of the motor while being safer. Quote
springer Posted December 11, 2011 Report Posted December 11, 2011 and also.....methanol doesn't make more power.....its more stable....meaning you can run more COMPRESSION to MAKE more power while keeping the chances of detonation lower. This allows you to throw more power out of the motor while being safer. wrong Quote
Jereme6655 Posted December 12, 2011 Report Posted December 12, 2011 so your saying that alcohol makes more power? i thought it was only more stable so you could make more compression without deto..... Quote
EvilBanshee Posted December 12, 2011 Author Report Posted December 12, 2011 I dont care about fuel milege, BUt i dont want to half to purge Quote
BANSHEE HP Posted December 12, 2011 Report Posted December 12, 2011 I dont care about fuel milege, BUt i dont want to half to purge just stay with gas then. Quote
EvilBanshee Posted December 13, 2011 Author Report Posted December 13, 2011 Fair enough. Thanks guys! Quote
