Bittner Posted December 5, 2011 Report Posted December 5, 2011 Hey guys im new the bansheehq and had my banshee for a couple months and ive been slowly noticing more and more that the right side cylinder is only firing once and awhile and less and less often. The guy i bought the quad from didnt know anything about the internals of the motor, it has k&n still in airbox an pro circuit platnum pipes and 304 silencers, when i got it seemed to me it was always running a little rich, no choke needed to start cold and would die after its warmed up. i took the lid off the air box and it idled better but the last 1/8 of throttle it would completly fall on its face no stumbling just pumping air. put the lid back on now raps all the way out but ive been noticing the right cylinder firing less and less. at about half throttle if i put my hand behind the pipes i can feel the right side is firing about half as much as the left. wondering where to start, i pulled the plugs both look a little rich but look the same none the less. kinda weary about tearing the carbs down just yet. Quote
lowbuckracing Posted December 5, 2011 Report Posted December 5, 2011 Welcome,Change your spark plugs,then get back to us. Quote
Jereme6655 Posted December 5, 2011 Report Posted December 5, 2011 when you change your plugs try switching the plug wires and see if the miss fire switches to the left cylinder.....thus allowing you to tell if your problem is a fuel or a electric problem Quote
Finch Posted December 5, 2011 Report Posted December 5, 2011 ya cheak plugs mine was doing it and i cheacked the wires and had top of an old spark plug stuck in it Quote
My03banshee Posted December 5, 2011 Report Posted December 5, 2011 Check plugs and obvious but take off your intake so you can see the throttle slides and make sure they are "in sync" and open the same amount at then start to crack the throttle and if one slide is starting to open before the other adjust the screw and nut on top....if good can also check the airfuel screw but need a airflow tool or vacuum gauge...its prob not the issue but it doesn't hurt to check and makes a big difference in how the engine runs. There's a few good vids of it youtube but pull the plugs...how do they look? One side diff than the other? Quote
Bittner Posted December 9, 2011 Author Report Posted December 9, 2011 Ok i finally made it out to the shop to change plugs and switched the plug wires around and it runs better overall but right cylinder still missfiring and dead if i hold it at a certain rpm for a period of time. then once i let off or get on it a little more it comes right back. I made sure the carbs were in sync when the problem first arose. an the old plugs both looked the same. From what ive been reading in diffrent forums i shud start looking for intake leaks now. Any other help would be much appreciated. Thanks guys. Quote
lowbuckracing Posted December 10, 2011 Report Posted December 10, 2011 Main jet clogged...on non firing side... Quote
Bittner Posted December 10, 2011 Author Report Posted December 10, 2011 Main jet clogged...on non firing side... Should i just clean the carbs up or rebuild them while ive got them apart? Quote
lowbuckracing Posted December 12, 2011 Report Posted December 12, 2011 Just take main jet and pilot out and make sure you blow them out and can see clearly through the main with no obstructions.. Quote
Bittner Posted December 19, 2011 Author Report Posted December 19, 2011 both carbs were spotless got it back together an re synched the carbs and now it switched to the other side so i dont have the carbs perfect in synch. atleast i know what it is now just a little fine tunning. thanks for all your help guys Quote
