cpi inframes
Will cpi inframes work well on a NOT ported 4mm long rod crank, vforce 3, .50 oversize pistons, and timing plate, stage 2 jets.
What timing would you use on the timeing plate?
They will work. T5's might actually be better on a non ported machine. I would get CPI's if you plan on porting and just need to buy new pipes now. If you plan on staying non ported then I would probably get a more traditional pipe.
