That is a very clean bike. Nice work!!!! Look forward to hearing how it rides.
  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
having the head cut with a modern dome design will do wonders for that engine. the MX guys used to drill the engine mount bolts out to the next size to help combat vibration issues.
  • 2 weeks later...
Took the 465 down to Wayne national forest. Runs like an animal. you can literally lug this thing around in 3rd,power is very tractable. I spent 4hrs on this thing and it passed all of its tests with flying colors..Even at slower trail speeds,the cylinder temps stayed withing the 200-220 range. Not as powerful as the 80 hp banshee I had,but It easily put my friends 686 rappy away. Not to mention the flickability the lightweight combination provides.
ok now the truth how many peeps have you told its a blaster motor??
also on the blaster there are these goofy rubber do dads on the fins that will help a TON with the aircooled rattle they have... might grab up a few sets and toss em on!
great build here.. i'd say this should be moved to the yfz conversion section..
It already has 2 of those rubber isolaters on the cylinder.the vibes are not bad at all,they are only noticable in the lower gears at peak rpm.there is no mistaking this engine for a blaster,sight or sound.If you know bigbore 2strokes, the sound is unmistakable.
I spent 400 on the rolling chassis minus the subframe. I used a yfz mx racer friend to source most of what i needed to finish the chassis.In total i have about $2000 into this project minus the "sweat equity" I will probably NEVER buy another factory quad again.i had too much fun building this one and after 2 hard rides,it has shown to be reliable on the trail.It helped to have access to a full machine shop with welding capabilities.
Everyone kept saying it would vibrate itself to death.But i did enough research and attempted to counter every issue i would face with this build.I think the biggest problem people face with conversions is the rear engine mount.The rear mount MUST use the swingarm bolt. i see a lot of guys fabbing up a there own rear engine mounting brackets. this is where most of the vibration is harnessed. You might be able to get away with it on a banshee engine,but on a non counterbalanced single,it won't happen. it will eventually break the mounts.
  • 1 month later...
  • 2 months later...
that one should be fun there was a modern yz250 put in one of these chassis a few years ago and it looked really good. nice combo
  • 3 months later...
