Ok so I am running a set of DMC 916's, my jetting is 27.5 pilot 280 mains and needle clip in the center. I have a k&n filter and a set of vf3's, and +4 timing.Motor is bored to 64.50.
Also i am at sea level. The bike runs great but seams to stop pulling hard in 4,5,6. Am I lean on the main? 30 pilot 280 main needle centered is the recommended jetting from DMC. They also say to use a 320 plus main with the powerpack that they sell, it uses a k&n filter. https://www.dmc-on-line.com/PDF/Banshee-916.pdf
My plugs look like they are on the rich side after riding for a while.
Any help here??????????????????
Thanks guys
If its rich then the plugs will show it. Ricky stator? They do that. If each gear like 4 5 and 6 feels exactly the same the clutch could be slipping as well.
anything??????????????????
Tell me what fuel your running. What kinda compression. Also how old are those plugs? Looks like your running a diesel lol Shes Fat.
Edited by EvilBanshee
Sunoco ultra 94
Kicking over 120 psi on both cylinders(stock head)
Plugs have like 10 hours
<br /><br />
<br />
Sunoco ultra 94 <br />
Kicking over 120 psi on both cylinders(stock head)<br />
Plugs have like 10 hours<br />
<br /><br /><br />
Thats why its not a proper plug chop. Old plugs will not work. Do it the right way.
Ya, get a fresh set. Gap them at .028 thou. Do a WOOT pass or 5 and check them right away. Then get back to me.
