hi again dear every one in banshee hq
i have doubt about new 10mil stock cylinder motor piston rings, the( gap, tolerance) between the rings and top of the cylinder sleeve at TDC is about 0.5mm, i wandering if it is ok for long period of operation see the pic pleas note this motor is running great,i would like experts opinion , pleas
pic from up
pic from up
if you have .5 mm plus the thickness of the ring that's about .060" . How thick is your squish ? I would think your piston would smash your head before your rings pop out . Do you have a link for the sleeves you're running ?
thank you dear for replying to my post , i would say squish is about 0.045-0.050 and with the old 4mil motor my piston kissed my head, rings did not pop out i m still useing the same piston for this 10mil motor,i would ask what is link for the sleeves?:)
ebay says your sleeves were stock porting . Did you change anything ? How does it run ?
yeah i only lined up the bottom of the ports with the top of the piston at BDC i did not touch the top of the ports due to timing is 199*/130* so the motor running great and strong but i m worry with high rpm and temperature the rings might pop out i do not know if accident waiting to happen.
Edited by banshee9090
how thick is your base gasket in these pics?
If you are worried about the top ring, run a thicker base gasket or a spacer to get a clearance you are comfortable with it.
yes dear my base gasket right now is 1mm, that is good way you suggested ,i m going to run another 0.5mm stander base gasket so the squish will be 0.059 do you think it is good squish for pump gas or i have to replace the dooms?
I would put it together and see what I came up with for head clearance before changing anything else.
yes dear tomorrow i will do that thanks :)
