banshee9090 Posted September 8, 2011 Report Posted September 8, 2011 hi again dear every one in banshee hq i have doubt about new 10mil stock cylinder motor piston rings, the( gap, tolerance) between the rings and top of the cylinder sleeve at TDC is about 0.5mm, i wandering if it is ok for long period of operation see the pic pleas note this motor is running great,i would like experts opinion , pleas pic from up Quote
banshee9090 Posted September 8, 2011 Author Report Posted September 8, 2011 hi again dear every one in banshee hq i have doubt about new 10mil stock cylinder motor piston rings, the( gap, tolerance) between the rings and top of the cylinder sleeve at TDC is about 0.5mm, i wandering if it is ok for long period of operation see the pic pleas note this motor is running great,i would like experts opinion , pleas pic from up one more pic. Quote
mikechief Posted September 10, 2011 Report Posted September 10, 2011 if you have .5 mm plus the thickness of the ring that's about .060" . How thick is your squish ? I would think your piston would smash your head before your rings pop out . Do you have a link for the sleeves you're running ? Quote
banshee9090 Posted September 10, 2011 Author Report Posted September 10, 2011 if you have .5 mm plus the thickness of the ring that's about .060" . How thick is your squish ? I would think your piston would smash your head before your rings pop out . Do you have a link for the sleeves you're running ? thank you dear for replying to my post , i would say squish is about 0.045-0.050 and with the old 4mil motor my piston kissed my head, rings did not pop out i m still useing the same piston for this 10mil motor,i would ask what is link for the sleeves? Quote
mikechief Posted September 10, 2011 Report Posted September 10, 2011 the sleeves aren't stock are they ? Where did you get them ? Quote
banshee9090 Posted September 10, 2011 Author Report Posted September 10, 2011 the sleeves aren't stock are they ? Where did you get them ? it is wsm HEAVY DUTY replacement sleeve i got that from ebay http://cgi.ebay.com/ebaymotors/YAMAHA-BANSHEE-ATV-2-STROKE-PISTON-SLEEVE-HVY-DUTY-/200423423313?pt=Motors_ATV_Parts_Accessories&hash=item2eaa2abd51 Quote
mikechief Posted September 10, 2011 Report Posted September 10, 2011 ebay says your sleeves were stock porting . Did you change anything ? How does it run ? Quote
banshee9090 Posted September 10, 2011 Author Report Posted September 10, 2011 (edited) ebay says your sleeves were stock porting . Did you change anything ? How does it run ? yeah i only lined up the bottom of the ports with the top of the piston at BDC i did not touch the top of the ports due to timing is 199*/130* so the motor running great and strong but i m worry with high rpm and temperature the rings might pop out i do not know if accident waiting to happen. Edited September 10, 2011 by banshee9090 Quote
tedd1 Posted September 10, 2011 Report Posted September 10, 2011 how thick is your base gasket in these pics? If you are worried about the top ring, run a thicker base gasket or a spacer to get a clearance you are comfortable with it. Quote
banshee9090 Posted September 10, 2011 Author Report Posted September 10, 2011 (edited) how thick is your base gasket in these pics? If you are worried about the top ring, run a thicker base gasket or a spacer to get a clearance you are comfortable with it. yes dear my base gasket right now is 1mm, that is good way you suggested ,i m going to run another 0.5mm stander base gasket so the squish will be 0.059 do you think it is good squish for pump gas or i have to replace the dooms? Edited September 10, 2011 by banshee9090 Quote
tedd1 Posted September 10, 2011 Report Posted September 10, 2011 Have you already cut the domes for the 10 mil crank? Quote
banshee9090 Posted September 10, 2011 Author Report Posted September 10, 2011 Have you already cut the domes for the 10 mil crank? yes dear already cut ! Quote
tedd1 Posted September 10, 2011 Report Posted September 10, 2011 I would put it together and see what I came up with for head clearance before changing anything else. Quote
banshee9090 Posted September 10, 2011 Author Report Posted September 10, 2011 I would put it together and see what I came up with for head clearance before changing anything else. yes dear tomorrow i will do that thanks Quote
camatv Posted September 11, 2011 Report Posted September 11, 2011 can you PLEASE stop calling peeps dear.. so you have a cool head with the domes cut up that much? Quote
