BigRed350x Posted September 3, 2011 Report Posted September 3, 2011 • Stock-Stroke, 65.5mm Bore • Dune-Port from Kevin Herr @ HJR Racing in Encinitas California. • Pro-Design Cool Head w/ 20cc Domes • Wiseco ProLite Piston Kit (less than 10hrs on new top end rebuild) • Boysen Epoxy Reeds • Stock Carbs w/ TORS Eliminator Kit & Cascade Idle Screws • Billet Clutch Basket • Cascade Innovations Billet Water-Pump • Renthal bars • Hyper Performance Clutch Perch & Lever • LSR Billet Front Hubs (no front brakes) o Stock Front Hubs w/ Front Brakes Available instead of Billet Hubs • WhiteKnuckle racing steel idler gear bushing • Modified Shift-Star • Modified Shift Shaft • New OEM Shift Forks & Rods (Same run-time on these as top end) • Cascade Pancake Bearing on Clutch Pushrod • Bead-Blasted OEM Cases • DG Billet Case-Guard • Pro-Design Billet Adjustable Timing Plate • FMF Gold Signature Series Pipes • FMF Power-Core II Silencers • Tusk HD Clutch Kit • Primary Drive 520 X-Ring Chain • Pingle Dual Fuel Petcock • DG Rear Grab Bar • RMATV Spring Flag Mount • Motion-Pro Throttle Cable • Motion-Pro Clutch Cable • Baja Style Front Bumper • Lightened Frame. (44lbs) • K&N Pod Filters w/ Outerwears • Braided Steel Rear Brake Line • Pro-Design Billet Power-Shifter • Tusk Clear Fuel Lines & Breather Hoses • 22x11x8 10-Paddle Skat-Trak Extremes • Cascade Innovations Billet Stator Cover • Billet Water Pump cover • Works Shocks Co. Rebuilt Revalved Rear Shock w/Works Gold Valve & Eibach Spring • Fireball Racing +8 Round Tube Chromoly Swingarm (Chrome) • ModQuad Billet Dual Row Roundhouse Carrier Bearing • Billet Parking Brake Block-Off Plate • EBC Brake Pads • 14T Primary Drive Front Sprocket • 44T Primary Drive Rear Sprocket • Billet Steering-Stem Bar Clamp • Billet Thumb-Throttle Cover • Billet Thumb-Throttle Lever $3000 OBO Just don't ride much any more & I have way more fun with my sand-rail. Someone else can get more ride time on this banshee. Runs great, fast for a stock-stroke, nice smooth power with Kevin's porting. Runs on pump-gas. I've ridden for about an hour or two only a handfull of times since I rebuilt the whole engine. The bike has +2+1 A-Arms and YFZ shocks in the pics, but these items are NOT included. It will come with stock A-Arms and a set of works front shocks. I can deliver up to 400 miles of Cheyenne, WY for the $3k price. I can give any pics and any videos anyone would like to see. Its the Red one in this pic. Quote
BigRed350x Posted September 3, 2011 Author Report Posted September 3, 2011 Oh yeah, case are port-matched to the cylinders. Quote
Strm Trpr Posted September 3, 2011 Report Posted September 3, 2011 Wow... Bump for a great deal! Quote
Zwiser Posted September 5, 2011 Report Posted September 5, 2011 Are you willing to part it out? Quote
Colby Posted September 5, 2011 Report Posted September 5, 2011 I wish you would have posted this two days sooner than you did .... :/ Quote
BigRed350x Posted September 5, 2011 Author Report Posted September 5, 2011 Are you willing to part it out? No thanks. If it doesn't sell I'm still riding it. Quote
BigRed350x Posted September 5, 2011 Author Report Posted September 5, 2011 I wish you would have posted this two days sooner than you did .... :/ Sell whatever it is that you got and buy mine. Quote
