So today i let one of my buddies(rides a blaster) have a go at my shee. He made a couple of passes long passes on a gravel road until he called me saying that he was sorry because he messed up my clutch. So i ride over to him and he proceeds to tell me that he was just shifting and all of a sudden the clutch lever had no tension on it and it started revving out so he hit the kill switch. Upon inspection i found that the clutch cable worked its self out of the slot it gets held in on the actuator arm so i put it back in and still nutting.The spring on the actuator arm still has tension on it, and it still will go through all gears when i pull the lever or do it manually but my cable still has no tension on it . I'm still pretty new the banshee and have only had one for a little over a month, and have never dealt with a problem like this on my other quads. So i was wondering if my spring on my actuator arm is getting worn, or my cable is just stretched that badly......or some other crazy solution that can only be know by those ridiculously knowledgeable bhq members :notworthy: . All info Appreciated-thanks
first of all I did not know oprah rides a shee! I hope the throttle gets stuck!!! lol JK
Ok so. just to clarify. if you pull the clutch cable off can you pull the clutch arm?
if you can then there is a problem in your clutch cover. I highly doubt that your friend did this. good luck.
I would pull the clutch cable and see if its still a solid cable or if you have a break in it somewhere. If you don't find the problem pulling the clutch cable, then it sounds like its time to pop the clutch cover off and do a little inspection. Its really not hard at all to remove the clutch cover. Make sure if you do that you have a new clutch cover gasket to put on when you replace the cover.
- Jared
yeah i can push the arm in but it has enough spring to pull its self back though.
no brakes in the line, however i did notice that even if i manually push in the actuator arm i still have no clutch (ie. it wont roll in gear).
what do guys think i am looking at here?
thanks in advance
thanks in advance
Your adjuster inside the case worked itself loose.
