I Purchased my first banshee a little over a week ago. it ran great for about five rides but two days ago i went to start it up and it turned over on the first kick but as soon as i got off of it and it shut down and hasnt ran sense.
After about 6950 kicks and some starting fluid i came to the conclusion that it wasn't getting spark, i checked the plug against the block and the and the frustration began. So i read the banshee electrical faq and broke out the multimeter heres what i found. Stator 27.6 ohms, pick up coil 123.1 ohms, i measured the ignition coil from plug boot to plug boot (correct me if i am wrong on that) 15.5k ohms. the kill switch and key switch both check out fine. I opened the cover for the stator and found some water (must have been there awhile because i haven't ridden though water or in the rain) , the fly wheel was slightly rusted i sprayed the stator the best i could with a degreaser and electric cleaner. i dont yet have a flywheel puller so i cant remove it. i tested the plug wires with a voltage tester and it lit up but very dimly when i kicked over.
I know the stator resistance is a little high and the ignition coil measurement i got is out of wack. im just looking for some opinions for further testing procedures or the possible culprit. thanks in advance
