ok guys when i first got this bike i cranked it for the first time to see how she run i notice while running that water was leaking from the head over the left pipe so i change head gasket but upon changing i notice that the right piston or the drive side piston had like a brown pudding like stuff sitting there guys what is that? also i notice that water is running down the cylinder walls even into the ports also. i have not remove top end yet just dryed and blow clean the gue off the piston so now i notice that if no water is in the motor bike will run now you fill with water after replacing gasket plugs and fresh gas bike will not run plugs are wet again im thinking of just pulling the top off.
Def pull the jugs off and see what is going on in there. it will only get worse. Nothing like fixing a problem before it cost you double the amount.
yes im sure as long as there is no water in system bike will crank and run fine soon as u put water in it the piston go swimming again going to pull topend this week and let you know what the bottom looks like
