okay, so my damn shee is firing outta the left side wayyyy more than the right.. really smokey :( what could this be?
You need to see if you are getting spark to the right cylinder. Then you need to make sure you have your jetting correct. Also was there anything that was messed with I.E. what did you mess with lol
check for spark,check jetting and confirm you dont have a head gasket issue
well, i have spark.. idk if this fixed the prob or not but i seen that the idle on both carbs was set wayyyy offf rom each other, so i turned the idle on both all the way in at the same time and the one side started smoking like the left side.. idk if that helped or not haha
haha hwat do ya mean by I.E.?
