If your slide is the circle thing that comes out when you screw the top of the carb off I couldn't have put it in backwards because it had a slot in it and their is a little thing in the carb on the wall that it slides down into so you can't put it in backwards but that is the only thing that I took out and I didn't adjust anything else just sprayed the entire thing down with carb cleaner
