106 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
What does it run, Jay...and have you had any issue with the plating?
Who's dyno was this run on?
(Not doubting, just asking the questions that all drag racers ask...)
Just got it back yesterday...havent got it in the frame yet....i had plating issues after a few passes when i kept burning the tips off my plug on one side.....
it was my fault b/c of carb issues and jetting....when rob got my motor with carbs he stated that the carbs was not jetted right as far as the dumb tube
and main jet was not right.....it was sent to plating to get the real nikacil done after i fucked it up and he put it back together and did his majic to the carbs and dynoed
it and came up with those numbers 5th gear pulls
im bout to send my 16mm cheetah to him now to see what he can do with that for me......
I've yet to see any Chinese aftermarket cylinder put down any respectable numbers.
This would be a first. I'd like to see real world numbers out of this...thanks Jay.
Rob does his own porting to the cylinders so i guess u would call them rdzinese cylinders.....hopefully i will get it to the track tomorrow or next weekend
So true....have u seen or heard of the cylinders wicked has come out with
Wicked New Cylinders
Wow...just wow...:)
CP is actually coming out with a "Alley Cat or Wompus Cat" I believe is the name.
ON the outside, they look like factory stockers.
They are actually the same (I believe) as cub cylinders inside.
How about 10mill Serval??
I´m not sure can you buy one yet but anyway... I think it can hit over 90 with race gas and good pipes, and I think it´s not as violent as a 10mill CUB.
whoops
like i said those chinese athena, vito,s painted black, athenaito'simported cylinders should run pretty respectable IF they have the right porting. being that they have very similar issu'e with port's as stock a "real" porter is going to have to get in there and do some real work they arent a bolt on and make 100hp cheeta motor seeing that RDZ is known for thier experience with stock cylinders i'm not suprised at all that they can make decent power out of that type of cylinder. now i'd like to see that motor make the same numbers after its in your frame on on a seperate dyno. should run pretty good
whoops
We shall c.....i hope it runs as good as it dynoed.....
