01BANSHEE49660 Posted February 7, 2011 Report Posted February 7, 2011 I am in the process of bringing a 89 Banshee back to life, it lost spark and was put in a pole barn and there she sat for 5 years untouched. I need to replace all the gas lines. I have been looking and i am seeing different sizes. What size is the fuel lines? Where can i get some new ones? Are they all the same size? On another note about the spark issue, i was reading through the manual and it said that the TORS could cause it not to spark? Is that the case? On the older Banshees do they have the stator issue or do you think that it could be the tors? How do i go about figuring it out. I have heard that you can test the stator and it will test good but actually be bad. I was told that my banshee you could kick it 10-15 times and get a spark maybe once? Any help would be greatly appreciated. Quote
Jereme6655 Posted February 7, 2011 Report Posted February 7, 2011 you can disable the TORS by unplugging it.....its the little black box that's under the gas tank on the left side. Quote
Larry's Shee Posted February 7, 2011 Report Posted February 7, 2011 (edited) Oopps, thinking of one thread , posting in another Edited February 7, 2011 by Larry's Shee Quote
chevybanshee91 Posted February 8, 2011 Report Posted February 8, 2011 you get new gas lines at any auto parts store/ fleet farm/ yamaha dealer... forgot what size it is but just take the old line and compair.. as for spark i would say stator.. those thing go out on shee's like nothing else. and you can just unplug the tors on that little black box. and check the stator where it unplugs wiht a ohms meter .. you'll have to research the correct proceedure i forget exactly on how to. Quote
brodysblanshee Posted February 8, 2011 Report Posted February 8, 2011 5/16" for the fuel line I diagnosed a TORS issue today by unplugging the connector at the black box as well as the two connectors coming off the factory carb caps... I had a spark issue before unplugging all of that and afterward I didn't, so you can troubleshoot TORS that way... Quote
