brodysblanshee
About brodysblanshee
  • Birthday 10/14/1984
Contact Methods
  • AIM
    BFCamaroRS355
  • Website URL
    http://
    Corpus Christi, Texas
brodysblanshee's Achievements
  1. How hot do they get when drag racing on a summer day in Texas? Idk, but probably hotter than what I want to touch...
  2. 5/16" for the fuel line I diagnosed a TORS issue today by unplugging the connector at the black box as well as the two connectors coming off the factory carb caps... I had a spark issue before unplugging all of that and afterward I didn't, so you can troubleshoot TORS that way...
  3. how much do you want for just the a-arms?
  4. Any chance you got a stock clutch basket with gear around???
  5. I bought my Banshee with mods below: K&N Pod filters Cool head with 18cc domes T5s +4 timing plate It ran awesome and when I finally tore into the carbs I found 300 main jets, stock pilots, stock needles (forgot where they were at though). Now, I
  6. I bought a tusk clutch a couple months ago and went to put it in today. When I disasembled the clutch I found that there weren't any of the o-rings between the friction plates and the clutch plates. So I put to tusk in there without any and couldn't get it together right. Is there supposed to always be o-rings (I know they aren't exactly o-rings...) or is it a stock only thing?
  7. Just got the shee about 5 weeks ago, and it already had T5's, single K&N w/ pro-flow, pro-design cool head with 19cc domes... The bike has always ran perfect, I've pulled the plugs a few times and they have been right on. So as of right now, I don't even know what jets/needles the former owner has in it (he told me but I forgot) Now I'm adding a few mods to it and would like to get some suggestions as to which jets I should buy. I'm adding timing plate (+4), v-force 3's, and dual K&N's. I run at sea level and it's usually 85 to 100 degress outside when I'm riding, humidity is always up there too. I'll prolly pull the carbs and check the jets that are in it now. But I'm just looking at some suggestions as to which jets/needles to purchase for tuning purposes... Thanks Brady
  8. Depending on your riding I would step up to a 13T or 14T front sprocket...
  9. That's awesome
  10. Um, I believe he was AGREEING with you man...
