the baddest banshee Posted January 7, 2011 Report Posted January 7, 2011 how can i check if i have a bad bottom end bearing? they roll like sooth ball bearings? i boght a engine unknown assembled i pulled cylinders do i have to split cases to check the crank bearings? Quote
Nieskes Posted January 7, 2011 Report Posted January 7, 2011 what works best is if you hold it wide open for 2 mins, if it dosent make noise your good. Quote
the baddest banshee Posted January 7, 2011 Author Report Posted January 7, 2011 what works best is if you hold it wide open for 2 mins, if it dosent make noise your good. i bought it in pieces i wanna check if its good before i reassemble the engine thnx! Quote
Nieskes Posted January 7, 2011 Report Posted January 7, 2011 Well when you get it all done, thats the first thing I would try. Quote
1bad450r Posted January 7, 2011 Report Posted January 7, 2011 what works best is if you hold it wide open for 2 mins, if it dosent make noise your good. lol. 2 mins, i thought it was 20? Quote
1bad450r Posted January 7, 2011 Report Posted January 7, 2011 i bought it in pieces i wanna check if its good before i reassemble the engine thnx! If you really wanna check the bottom end out you're gonna have to split the cases bro. Quote
the baddest banshee Posted January 7, 2011 Author Report Posted January 7, 2011 If you really wanna check the bottom end out you're gonna have to split the cases bro. how do i "check" or do i just send it to get welded if i got it out? Quote
Jereme6655 Posted January 7, 2011 Report Posted January 7, 2011 Welcome to the HQ! Some of us here will jerk you around every now and then.......like running it pinned wide open on a compeltely fresh motor haha.... to really check the bearings and to make sure your crank hasn't begun to seperate...you will need to split your cases. and while its apart if your planning on modifying the motor at all then you should really think about sending the crank out and getting it welded by a site sponsor. I recomend Jeff at F.A.S.T......damn good guy and damn good work! Quote
the baddest banshee Posted January 7, 2011 Author Report Posted January 7, 2011 Welcome to the HQ! Some of us here will jerk you around every now and then.......like running it pinned wide open on a compeltely fresh motor haha.... to really check the bearings and to make sure your crank hasn't begun to seperate...you will need to split your cases. and while its apart if your planning on modifying the motor at all then you should really think about sending the crank out and getting it welded by a site sponsor. I recomend Jeff at F.A.S.T......damn good guy and damn good work! thankyou now how do i check if its good? if i send it to get trued and welded by FAST how much approximately would that run? one more question the motor i got has 1 ported intake runner 1 stock intake runner. do you recomend porting the other cyl to match myself or send it to FAST also? how much would that cost? Quote
the baddest banshee Posted January 7, 2011 Author Report Posted January 7, 2011 thankyou now how do i check if its good? if i send it to get trued and welded by FAST how much approximately would that run? one more question the motor i got has 1 ported intake runner 1 stock intake runner. do you recomend porting the other cyl to match myself or send it to FAST also? how much would that cost? the crank seems ok no play or crunching in bearings shud i split the cases and check it out? Quote
Hilarious Posted January 7, 2011 Report Posted January 7, 2011 the crank seems ok no play or crunching in bearings shud i split the cases and check it out? If it was me, i would split the cases. It is not hard to do. You need a good dial gauge to check true on your crank. Also check all the tolerances to see if its separating. Might as well pull it and send off for a true & weld. Its good assurance. The crank is the heart of your engine. 50 or 75$ not sure what the going rate is these days. Quote
the baddest banshee Posted January 7, 2011 Author Report Posted January 7, 2011 If it was me, i would split the cases. It is not hard to do. You need a good dial gauge to check true on your crank. Also check all the tolerances to see if its separating. Might as well pull it and send off for a true & weld. Its good assurance. The crank is the heart of your engine. 50 or 75$ not sure what the going rate is these days. any special tools needed to remove and install crank? besides flywheel puller? Quote
Jereme6655 Posted January 7, 2011 Report Posted January 7, 2011 its $75 at FAST to have it trued and welded. You can call Jeff and ask him about the cylinders and what he would recommend.....he will tell you his honest opinion. He's a really great guy that stands behind his work and has made many of our bikes lay down some serious power. Www.farmandsandtoys.com Quote
Hilarious Posted January 7, 2011 Report Posted January 7, 2011 any special tools needed to remove and install crank? besides flywheel puller? The flywheel puller is the only exotic tool you will need. A 1-1/4 socket or 32mm to remove the clutch hub. Quote
