the baddest banshee
Everything posted by the baddest banshee
  1. pm me a price for everything!!!
  2. how do i measure ea. of those? whats the tool called for measuring these tolerances?
  3. actually thats how i diagnosed the bad crank i redlined it till it stopped running and my frend sed however many minutes that took thats how many degrees out of true my crank is! it was actually 31 degrees out of true!!! good thing i cought this before it broke down in the woods! i will make sure to test my new crank in this manner to make sure my new one is really trued!!
  4. actually thats how i diagnosed the bad crank i redlined it till it stopped running and my frend sed however many minutes that took thats how many degrees out of true my crank is! it was actually 31 degrees out of true!!! good thing i cought this before it broke down in the woods! i will make sure to test my new crank in this manner to make sure my new one is really trued!!
  5. any special tools needed to remove and install crank? besides flywheel puller?
  6. the crank seems ok no play or crunching in bearings shud i split the cases and check it out?
  7. thankyou now how do i check if its good? if i send it to get trued and welded by FAST how much approximately would that run? one more question the motor i got has 1 ported intake runner 1 stock intake runner. do you recomend porting the other cyl to match myself or send it to FAST also? how much would that cost?
  8. how do i "check" or do i just send it to get welded if i got it out?
  9. i bought it in pieces i wanna check if its good before i reassemble the engine thnx!
  10. how can i check if i have a bad bottom end bearing? they roll like sooth ball bearings? i boght a engine unknown assembled i pulled cylinders do i have to split cases to check the crank bearings?
  11. how can i check if i have a bad bottom end bearing? i boght a engine unknown assembled i pulled cylinders do i have to split cases to check the crank bearings and rod lower bearing?
  12. i will pay $50 for carbs and boot $5 for rear sprocket $5 for throttle cable $15 for a rear rim (j arm) $20 for complete stock exhaust all parts in usable condition pleese plus ill pay shipping thnx for the help in advance! happy holidays!
  13. i have 20 inch chrome 5 lug universal rims and tires for a bansheee motor prefer running prefer near ny also have a coleman powermate generator 6250watt works great! wiill trade rims and gen for a decent motor may be able to add couple hundred cash after christmas http://s1183.photobucket.com/albums/x467/zzakariah23/ i also need carbs/ intake boot/ rear sprocket/ complete exhaust/throttle cable/a rear rim http://s1183.photobucket.com/albums/x467/zzakariah23/banshee/
  14. http://s1183.photobucket.com/albums/x467/zzakariah23/
  15. YOU GOT A PINHOLE LEAK SOMEWHERE IN THE BRAKE SYSTEM USE BLACKLIGHT DYE AND A BLACKLIGHT IF U CANT FIND IT!!!
  16. i need a complete motor with carbs and exhaust prefer bolt in and go. will take motor that needs work will take a box of parts that makes a motor im very broke and just wanna go riding i dont care about chrome polished or race motors i need some reeeeel budget stuff right now also need 1 rear rim and a throtle cable! thnx 845 494 8123 [email protected] happy holidays ! help a brother out!
  17. IM FNG ANYONE WANNA POST A REPLY THAT SAYS HOW I ADD PICS?? OR POINT ME IN THE RT DIRECTION?
  18. okay folks i got some fresh 20's 5 lug universal no curb scratches no pitting tires are 75% tread falkens im in need of a complete motor tranny for a banshee preferably with a wire harness preferably motor will be running and shifting good i dont mind stock or modded i also need exhaust tires rear rim throttle cable !!!!!!!!!! also any old parts old stock stuff whatever anyone feels like giving away ill pay to ship it of course! do not hesitate im building this banshee junkyard wars style mad broke!!!! [email protected] or txt 845 494 8123 for pics i cant figure it out rt now!
