toomeysgoroom Posted December 8, 2010 Report Share Posted December 8, 2010 Can any one help me check te bead on a sand tire it has a leak i put ten psi and in 15 min its down to 5 psi Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted December 8, 2010 Report Share Posted December 8, 2010 Can any one help me check te bead on a sand tire it has a leak i put ten psi and in 15 min its down to 5 psi i only run 4-6psi in my paddles anyway. deflate the tyre and try to clean out the bead the best you can and check the valve for leaks. pump the tyre up and stick it in a bath, so you can see where its leaking from. Quote Link to comment Share on other sites More sharing options...
toomeysgoroom Posted December 8, 2010 Author Report Share Posted December 8, 2010 i only run 4-6psi in my paddles anyway. deflate the tyre and try to clean out the bead the best you can and check the valve for leaks. pump the tyre up and stick it in a bath, so you can see where its leaking from. Ok man ill try that thanx for the help Quote Link to comment Share on other sites More sharing options...
06specialedition Posted December 8, 2010 Report Share Posted December 8, 2010 If its a bead leak, the best way to do it is dismount the tire and put bead sealant on the wheel...then re mount and you should be good Most local tire shops can do this Quote Link to comment Share on other sites More sharing options...
J-Madd Posted December 8, 2010 Report Share Posted December 8, 2010 I've had to use fix-a-flat before, even after bead sealer was used. Quote Link to comment Share on other sites More sharing options...
frinkbc Posted December 10, 2010 Report Share Posted December 10, 2010 i have only done this to my truck tire but it works, ratchet strap the tire ( with the tire direction) tighten ratchet not too much, should only need a little squeeze, fill the tire with air the strap forces the air to go to the bead, let us know and good luck Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted December 10, 2010 Report Share Posted December 10, 2010 i have only done this to my truck tire but it works, ratchet strap the tire ( with the tire direction) tighten ratchet not too much, should only need a little squeeze, fill the tire with air the strap forces the air to go to the bead, let us know and good luck Just had to do that last night to re-seat 2 snow-blower tires because they popped off the beads. Sometimes you have to squeeze kinda decent on the tire.....basically you need to squeeze it so that the tire squishes the bead outward enough to get a seal between the tire and wheel...then start to inflate the tire slowly. Quote Link to comment Share on other sites More sharing options...
shee4speed Posted December 11, 2010 Report Share Posted December 11, 2010 Can any one help me check te bead on a sand tire it has a leak i put ten psi and in 15 min its down to 5 psi If it's the bead,you need to break the tire down off the rim,clean the rim very well (maybe use some steel wool). Be sure the rim is not bent. Make sure the tire is good,also clean very well. Remount. I have had tires that will continue to leak at the bead and just replaced the whole friggin set. Quote Link to comment Share on other sites More sharing options...
fastquad02blaster Posted December 15, 2010 Report Share Posted December 15, 2010 I would say to have them broke down and bead seal them. Before a dune trip, a buddy and I did this to two fronts. Popped them off the beads and liberaly coated them with rubber cement. Aired them back up and NO LEAKS. Worked like a charm. Quote Link to comment Share on other sites More sharing options...
