vbanshee Posted November 7, 2010 Report Posted November 7, 2010 ok so went to gordons bike was running pretty good. However later on I was riding it hesitates to hi the powerband not full power. Only about half the power. I replaced the top end about 5 months ago. Also the left side is smoking a little too much. Any info is good info thanks fllas Quote
12 0 Clock P I M P Posted November 7, 2010 Report Posted November 7, 2010 ok so went to gordons bike was running pretty good. However later on I was riding it hesitates to hi the powerband not full power. Only about half the power. I replaced the top end about 5 months ago. Also the left side is smoking a little too much. Any info is good info thanks fllas do you have TORS? smoke could be due to air leak - do a leakdown test...... how are your reeds??? cracked? Quote
Larry's Shee Posted November 7, 2010 Report Posted November 7, 2010 Was there a large temperature change? Elevation? Fuel out of different jug ,maybe old or different some how? Air cleaners get dirty? Just a few thoughts. JMHO , your results may vary. Quote
68chevyc10355 Posted November 7, 2010 Report Posted November 7, 2010 wouldnt hurt to do a compression check while your at it Quote
vbanshee Posted November 7, 2010 Author Report Posted November 7, 2010 tors has been removed. reeds seem fine i run the vfroce 3 reeds elevation was close enough to sea level. ill dot he tests asap Quote
thrill-billy85 Posted November 9, 2010 Report Posted November 9, 2010 Ya I had that problem a while back.... It was my v force 2 reeds. Still ran... Like hell. Pull ur reeds out an actually LOOK at them.... I have pictures of what mine looked like on my profile... Quote
