Banshee Racer32 Posted September 24, 2010 Report Posted September 24, 2010 i just put a cool head with 21cc domes and v force reeds the compression is 160psi i cant get it to idle andi was wondering if it was my jets and al so i have pro cercit platnum ex boost bottal with K&N pods and im at 2000feet elavation and im fixing to be rideing in about 60 to 32 degree wather in the next 4 to 5 weeks but its around 70 80s untill then so can some one please help me Quote
tedd1 Posted September 24, 2010 Report Posted September 24, 2010 Did it start acting up when you put new parts on? If so, retrace your steps. Is the crossover tube between the carbs? Slides in the correct carb/ in the carb correctly? Is there an air leak on the intake between carbs and motor? Quote
Banshee Racer32 Posted September 24, 2010 Author Report Posted September 24, 2010 Did it start acting up when you put new parts on? If so, retrace your steps. Is the crossover tube between the carbs? Slides in the correct carb/ in the carb correctly? Is there an air leak on the intake between carbs and motor? NO I WAS RACEING A HAIR SCRAMBLE AND ABOUT 15 MILES IN IT DIDENT WANA RUN AT ALL I THOUGHT SOME WATER GOT SUCKED UP CUZ THE K&N PODS SO I BOUGHT NEW REEDS AND A HEAD JUST FOR THE HECK OF TO SEE IF IT WOULD FIX THE PROBLEM BUT IT WONT AND THE LEFT SIDE EX HAS BARLEY ANY EX COMEING OUT THE PIPE IT NOT THE PLUG OR THE COIL I ELIMNATED THAT OUT I WAS TOLD 160PSI IS RACE GAS TEROTORY IS THAT TRUE IF SO COULD THAT HAVE ANYTHING TO DO WITH IT I JUST WANNA GET HER GOING AGAIN SO ANY HELP WOULD BE WONDERFUL ALL SO ITS GOT A BOOST BOTTEL NOT CROSOVER TUBE Quote
bode1 Posted September 24, 2010 Report Posted September 24, 2010 He means the small black straight rubber tube between the tubes. Quote
Larry's Shee Posted September 24, 2010 Report Posted September 24, 2010 (edited) What carbs do you have and what jets are in it? If they're stock is tors still hooked up? Edited September 24, 2010 by Larry's Shee Quote
Banshee Racer32 Posted September 27, 2010 Author Report Posted September 27, 2010 (edited) What carbs do you have and what jets are in it? If they're stock is tors still hooked up? O ya the tube between the carbs is there and there stock carbs and yest the tores are still there not for long tho and i think the main is a 280 or 285 but i have no idea what he piolit is and heck it might be a 185 i cant really make out the numbers Edited September 27, 2010 by Banshee Racer32 Quote
tripledsracing Posted September 30, 2010 Report Posted September 30, 2010 O ya the tube between the carbs is there and there stock carbs and yest the tores are still there not for long tho and i think the main is a 280 or 285 but i have no idea what he piolit is and heck it might be a 185 i cant really make out the numbers get rid of the tors crap nothin but a headache!..sounds like your intake may be leaking,also clean your pilot jets.. Quote
