I have a ? and i really need a fast respnse what would be a good piston ring brand or kit with webstie or wile the jugs are off should i get a new piston kit to if so whats the best but cheepest kit i can buy i can only spend around $120$
I got a 06 banshee with a cool head 20cc domes procercut pipes delta force reeds K&N pods i cant get it to idle and there is little to none exhaust comeing out of the left cylender and i cant really get a comp reading on the left side and i think its my piston rings what do yall think any advice will be grat thanks
O ya the tube between the carbs is there and there stock carbs and yest the tores are still there not for long tho and i think the main is a 280 or 285 but i have no idea what he piolit is and heck it might be a 185 i cant really make out the numbers
NO I WAS RACEING A HAIR SCRAMBLE AND ABOUT 15 MILES IN IT DIDENT WANA RUN AT ALL I THOUGHT SOME WATER GOT SUCKED UP CUZ THE K&N PODS SO I BOUGHT NEW REEDS AND A HEAD JUST FOR THE HECK OF TO SEE IF IT WOULD FIX THE PROBLEM BUT IT WONT AND THE LEFT SIDE EX HAS BARLEY ANY EX COMEING OUT THE PIPE IT NOT THE PLUG OR THE COIL I ELIMNATED THAT OUT I WAS TOLD 160PSI IS RACE GAS TEROTORY IS THAT TRUE IF SO COULD THAT HAVE ANYTHING TO DO WITH IT I JUST WANNA GET HER GOING AGAIN SO ANY HELP WOULD BE WONDERFUL ALL SO ITS GOT A BOOST BOTTEL NOT CROSOVER TUBE
i just put a cool head with 21cc domes and v force reeds the compression is 160psi i cant get it to idle andi was wondering if it was my jets and al so i have pro cercit platnum ex boost bottal with K&N pods and im at 2000feet elavation and im fixing to be rideing in about 60 to 32 degree wather in the next 4 to 5 weeks but its around 70 80s untill then so can some one please help me
all so i just put a cool head with 21cc domes and v force reeds the compression is 160psi i cant get it to idle andi was wondering if it was my jets and al so i have pro cercit platnum ex boost bottal with K&N pods and im at 2000feet elavation and im fixing to be rideing in about 60 to 32 degree wather in the next 4 to 5 weeks but its around 70 80s untill then so can some one please help me
Hi i need some help my shee wont stop pouring out gas out of the overflow tubes so i took it apart and was looking at the inside and the flowats are not stuck they work fine i cant figure it out
ok i read all yalls conclusons its stock bore i raced a hairscramble be for i put the head and reeds on and half way threw the race it did not want to run at all so i took it home i know some water got sucked in the carbs so i pulled them off and cleaned them and it ran ok then i put the reeds and head on and the new problems started such as wont iddle dose not have the pop corn sound like a normal 2 stroke and it pours gas out the left carb and the floats arnt sticking makes no sence and its got 280 mains in it with all the upgrades and im at about 2000 feet elavation what should be in there and idk what the piolet is in there what do i need to put in i dont know if you kneed to know this but i also have a boost bottle also
ok so i need to run race gas can i just us 94 and use addative and for some reson my left carb just pours out gas makes no sence and the floats arint ticking what should my iddle scerw be set at and what size main and piolit jets should i use and just to make sure whats the tourqe spec on the head thanks alot for all your help so far
Wll the left cylender is not fireing it barely got ant ex come out and i swaped the plugwires and it dosent do anything same side is doing the same thing
