Hey guys, my banshee hasn't been acting right lately. At first we thought the coil went bad on it, so I bought a new one and put on it. Same problem. At WOT in any gear, it misses and sputters. And it's running hot really quick. Compression was 120 in both sides. My left plug is way lean compared to my right. What's the deal?
It's a 2001 and has T5's, VF3's, K&N no lid, and the infamous boost bottle (came with it, going to get a stock crossover soon).
Thanks for any help.
intake boots i think would cause you too lean out and would make sense. check the bottle it self. the cable will rub on the bottle and since the bottle is cheap aluminum, the cables will rub a whole in it.
Okay so today I looked over carb boots, intake and reeds and what not. Nothing appeared to be cracked but I did replace the gasket on the left side since it did appear to have shit leaking out of it. Put it all back together and still isn't running right. I kept it WOT sounds like it's loaded up really bad brought it back changed plugs and it seemed to run ALOT better than it did, but i still noticed a small miss in it. Let it cool off again for about 30 minutes took another ride on it and it's acting up and missing terribly. WTFF??
Could you have a bad elec. connection? Is the pickup at the stator gapped properly. Try to slowly eliminate if it's fuel or elec. The fuel line could be old, leaking, sucking air at carb fittings, etc...
