FadedDreams Posted September 20, 2010 Report Posted September 20, 2010 I'd like to get rid of the carb set-up i've been using for a while. They are 28mm Keihin PWK's that have been bored to 30mm. They will come with K&N clamp-on filters, throttle cable, and Air Speed intakes. Everything is in good shape. Only issue I can think of is that the carb tops could be rethreaded. They aren't stripped, but are getting worn out from when I was messing with different needle positions, I just use lock washers so the bolts hold tight. I'd like to get $250 shipped and i'll have pics up after 4pm tomorrow. Quote
FadedDreams Posted September 20, 2010 Author Report Posted September 20, 2010 Got some pics, I can get more if needed. I'll clean them up before sending, they have some dirt on them. Quote
BIGONTS Posted September 21, 2010 Report Posted September 21, 2010 So these were bored straight through to 30mm. Any other issues besides top screws? Slides good, etc...?? Thanks Quote
FadedDreams Posted September 23, 2010 Author Report Posted September 23, 2010 So these were bored straight through to 30mm. Any other issues besides top screws? Slides good, etc...?? Thanks These are bored straight through. Slides have some wear, but I ran them for at least 5 years, and I bought them used . I took some pics when I was cleaning them. Quote
FadedDreams Posted September 23, 2010 Author Report Posted September 23, 2010 Heres one of the intakes. I just realized it wasn't on here. Quote
