trickedcarbine Posted August 3, 2016 Report Posted August 3, 2016 Not much to talk bout. It's a 28 inch gun drilled 70 series top notch axleI need a wide axle, not their drag axle. He's pretty sure he can make it happen. Johnathan Tomlinson and I have been talking about doing a 40mm aluminum axle that is similar to JJ&A but wider and if fireball can't make it happen, I'll wait on him. We'll see. Frame is under way and I've about got everything here or on order. Quote
JTmachining Posted August 3, 2016 Report Posted August 3, 2016 I need a wide axle, not their drag axle. He's pretty sure he can make it happen. Johnathan Tomlinson and I have been talking about doing a 40mm aluminum axle that is similar to JJ&A but wider and if fireball can't make it happen, I'll wait on him. We'll see. Frame is under way and I've about got everything here or on order.Not sure size u need but there's options available that should work. Is that John even a machinist Quote
trickedcarbine Posted August 3, 2016 Report Posted August 3, 2016 Not sure size u need but there's options available that should work. Is that John even a machinistYeah, that guy that makes all those aluminum nuts, carbon water pump covers, and bearing support parts. He's done an axle already. It takes all JJ&A or any other brand parts that work on the keyed axles. (fastassbanshee96 on here) Quote
375hp banshees Posted April 20, 2018 Report Posted April 20, 2018 Which one, the one for sale in 2010 or the one bought in 2016 1 Quote
trickedcarbine Posted April 25, 2018 Report Posted April 25, 2018 Hey, can't fault a fella for trying. I bumped it 6 years after a cold listing and ended up getting pretty lucky. Quote
