n0blefart Posted August 23, 2010 Report Posted August 23, 2010 Money is not a problem, i just got my banshee first one a week ago. It is ported and has some cool mods, new pistons and the guys said he put 3 grand into the engine. All in all i want to drag it so want to make it very fast and dragable. I have kehien carbs or however theyre spelled with dual filter kit on it. I just want to know what would be the best way to go engine wise. Big bore? What pistons? What dome size and what head would be best. Also if theyres anything else i need let me know. I wanna run race fuel and drag. Thanks! BTW Im new and a fast learner but havent taken an engine apart but will be doing this one, not completly by myself... Thanks! Quote
bbcmudtruck Posted August 23, 2010 Report Posted August 23, 2010 You can spend a little money on the engine you have and make it pretty quick. Your question is kinda vague. What kind of terrain will you be dragging on? How long is the drag strip? Whats the competition like in your area? Quote
n0blefart Posted August 23, 2010 Author Report Posted August 23, 2010 You can spend a little money on the engine you have and make it pretty quick. Your question is kinda vague. What kind of terrain will you be dragging on? How long is the drag strip? Whats the competition like in your area? area of fine comp is easy pickings... 300 bucks every other sunday possible for the fastest overall fourwheeler cat. dirt drags... i just made all my purchases let me know if theyre okay. +6 inch swingarm, piston and cylinder kit bored to 68mm already, 38mm mikuni carbs, vforce 3 reed and reed cages. fiberglass front end, 10mm crank that goes with the pistons and cylinder, cool head and big bore 17cc domes for the head. also the kit is for tripple exhaust so i got a dzi or whatever tripple drag exaust out of frame. that sound good? Quote
EvilBanshee Posted August 23, 2010 Report Posted August 23, 2010 (edited) area of fine comp is easy pickings... 300 bucks every other sunday possible for the fastest overall fourwheeler cat. dirt drags... i just made all my purchases let me know if theyre okay. +6 inch swingarm, piston and cylinder kit bored to 68mm already, 38mm mikuni carbs, vforce 3 reed and reed cages. fiberglass front end, 10mm crank that goes with the pistons and cylinder, cool head and big bore 17cc domes for the head. also the kit is for tripple exhaust so i got a dzi or whatever tripple drag exaust out of frame. that sound good? Oh fuck ya!! that will work good. You ll have to run serious octain with that 17cc dome. Like straight 112. What make of engine kit is this?? and is it a 465cc?? Edited August 23, 2010 by EvilBanshee Quote
firebanshee Posted August 25, 2010 Report Posted August 25, 2010 17cc dome is to small for a 68mil bore at sea level.I would not go any smaller than 20cc on a 68mil bore at sea level.You will need to trench your cases for that crank. Quote
MikeNick Posted August 27, 2010 Report Posted August 27, 2010 You need to contact one of the builders that sponsor our site. They can assist with a motor. Quote
jbirdshee Posted August 27, 2010 Report Posted August 27, 2010 tripple exhaust? thats the same thing i was wondering??? sounds to me like the cylinders are just triple ported but this guy went off and bought an exhaust for a tripple??? hmmmmm Quote
