probably but if i were you i would do just the cylinder and skip the sleeve. the sleeve acts as a gaurd against the cylinder. honda came up with this idea to get rid of the sleeve completely so i would use it for that purpose. if you blow up then the sleeve itself could become damaged and then you would still have the same problem. so in short. i would do just the cylinder and get rid of the sleeves
You can't run the cylinders without the sleeves.. They have to be there.. no way around it.
what methyman said. You can nik the steel sleeves.
lol yeah jerk the sleeves out and run a set of 100mm pistons no biggie :rotflmao:
yes you can have the sleeves nikled and no you cant just take the sleeves out. some ppl's kids!
i think i'll just yank the sleeve out and run some 72 mm pistons and have a super sleeper. lol
thanka for the conformation guys . i was curious cause i might do it to hold on to the port work i have cause i really like the way it runs with the hjr job i have
Edited by robert0762
You can resleeve with ported cylinders. The sleeves will have to be port matched.
If your going to do that you might as well run big bore sleeves too. Dont get the huge ones. I had a pair of drag ported cylinder resleeved by dan a patiot racing. He used a 66mm-68mm sleeve. People claim that big bore sleeves choke down the transer ports. My 66-68mm sleeves still had aluminum in the transfer ports, so they were not any smaller than stock sleeves.
Yes you can get a steel sleeve nikasiled.
Are you 100% sure of that...?????
A nikasil co. in my area told said to me: no plating on steel sleeve. we have to switch the steel sleeve for aluminium one to get it plated
