dirtbike drew Posted July 13, 2010 Report Posted July 13, 2010 Hay just want some info is the boost bottle better then the stock balance pipe ? I read that it improve s throttle response and low-end power . But is it worth it and can u feel a deference or not and just stick with the stock ? .... Quote
sleeper06 Posted July 13, 2010 Report Posted July 13, 2010 Do yourself a favor and get the billet intakes with the crossover built in. Quote
dirtbike drew Posted July 13, 2010 Author Report Posted July 13, 2010 Ok where can I see them do u have a pic and who makes them what name brand and about how much do they run. I have stock carbs. I still have to do a top end rebuild on this I just got it about a month ago and was missing parts. So frist my working on getting it to run.... Just making a list of what aftermarket parts I should get.... Thanks. Quote
toytech Posted July 13, 2010 Report Posted July 13, 2010 Ok where can I see them do u have a pic and who makes them what name brand and about how much do they run. I have stock carbs. I still have to do a top end rebuild on this I just got it about a month ago and was missing parts. So frist my working on getting it to run.... Just making a list of what aftermarket parts I should get.... Thanks. Chariot performance, one of the site sponcers, they are around 150, the best way to go is one of theese intakes Quote
pondtunes Posted July 13, 2010 Report Posted July 13, 2010 Hay just want some info is the boost bottle better then the stock balance pipe ? I read that it improve s throttle response and low-end power . But is it worth it and can u feel a deference or not and just stick with the stock ? .... Don't use a boost bottle, they put excessive strain on your intake boots and will crack them causing an air leak and leaning out your air/fuel mixture. Stick with the stock pipe or upgrade to one of the aforementioned intakes. Quote
midlifecrisis Posted July 13, 2010 Report Posted July 13, 2010 and dont ask anymore stupid questions, use the search function next time, this has been talked about a million times too many already. and you sound like a new person here so welcome. Sure glad I didnt ask a "stupid question", give the guy a break, hes new here. Welcome bro! If youve been looking for a while, then you know how helpful this place can be, use it wisely, and yeah, Ill give you a helpful tip about a boost bottle, stick it under your bottom end when its time to rebuild, thats all theyre good for, and theyll hold your engine block at the exact angle you need!! Quote
GNR101 Posted July 13, 2010 Report Posted July 13, 2010 boost bottles all the way!!! the blue ones give good power Quote
bansheesandrider Posted July 15, 2010 Report Posted July 15, 2010 boost bottles all the way!!! the blue ones give good power Which blue ones? the blue one that says NOS on it or some other one? Where do you get the blue ones? lol Quote
ziegman Posted July 16, 2010 Report Posted July 16, 2010 Which blue ones? the blue one that says NOS on it or some other one? Where do you get the blue ones? lol The same place you bought your powerbands from. Quote
