i just got a cheetah motor and the over flow is just routed down the frame no overflow bottle with the new motor it keeps pissing out the hose when i ride it spraying all over. the old motor never did this.woud there be a reason y it is doing this with the new motor
A few questions:
Is the motor new or used? Does it leak right away? First time you pin the gas? After the motor warms up? Have you noticed any blueing of the exhaust? Have you read your plugs? Lean condition will also overheat the motor, but it usually takes a few minutes...
doesntleak bad and not all the time, my pipes r not blue and plugs look good
happened to me last week i rebuilt my motor but never re torqued the bolts to the head . if you did that than. bad o ring or gasket or bad impeller
