krauss4
Everything posted by krauss4
  1. What’s a good jetting starting point for a 472 4 mil super cub that’s drag ported with sb shearers in frames using 39 mm pwk cel needles and a 4.5 slide ?
  2. It’s non oxygenated
  3. I got a chance to buy a barrel of vp late model plus fuel for $5 a gallon. Anyone have any input on using this stuff ? Good bad ? I believe it’s 116 octane. Description says for larger engines so I’m a lil leery about trying it. I have a 4 mill cub been running c12 for many years
  4. Still available
  5. i want to start drainging my carb bowls after very use because im running race gas with hp2 oil and it says on the c12 gas do not keep in carb and it turns to syrup quickly.i have kehin pwk carbs, is there a kit you can buy for this without drilling or tapping your bowls? i thought about the snowmobile carbs and they have a factory water trap out the bottom of the carb where the nut is but not sure if it will screw in any one have n e ideas or show pics what u used
  6. im looking for a set of shears small bore out of frame same side WITH silenecers for a 421 cub n e one have some or know where to get them
  7. doesntleak bad and not all the time, my pipes r not blue and plugs look good
  8. i just got a cheetah motor and the over flow is just routed down the frame no overflow bottle with the new motor it keeps pissing out the hose when i ride it spraying all over. the old motor never did this.woud there be a reason y it is doing this with the new motor
  9. its just annoying it wants to die if im not on the gas after its hot
  10. i have small bore shears inframes 35mm keihns boss intake clean up port job 4 degrees tming advance
  11. they just made one at bundy hill in se michigan by devils lake its only 350 ft and that includes slwing distance so it kinda sucks
  12. got a 4 mill cub 35mm carbs idles when i first start it up but wont idle at all after its hot whats up
  13. it has heavy springs in it i dont think its the cable bc i just changed the motor out and the old motor didnt do it. would deep grooves in the basket cuse it to shift hard too?
  14. i just got a cheetah motor and it has a lockup clutch on it and i noticed that it shifts kinda hard and when i put it in gear nd pull the clutch in and rev it up it wants to move a little bit. i have adjusted the clutch to where it pulls allthe way in and still wont stop n e ideas?
  15. i had it out today and im pretty sure im rich all around bc i think its loading up at idle with a 55 pilot and im not sure but in 6th gear wot its either lean or way rich bc theres no power there with a 178 main and a dgh needle. i was wondering does the needle have n e thing to do with wot
  16. i have been runnng vp c12 for a while and am paying 75 dollers for a 5 gallon drum is it the same quality gas that u can buy at like sunoco for like 6 bucks a gallon thats 110 octane. or i can buy high octane gas at a local dirt track where they race late model cars at for real cheap. whats the differance
  17. i have dgh needles will this change the way i need to jet
  18. 35mm air strykers pretty much sealevel in ohio will downsizing in main jet size have n e thing to do with idle
  19. i just got a 421 cub and i call d and m who built the motor and they told me to start with a 178 main and a 55 piolet with dgh needle so that what i got and the plugs are wet so its obviously rich but it runs pretty good but it doesnt idle what changes should i make. i have 35 mm airstrikers with shears small bores and a clean up port job
  20. i know its an 2001 harness so thats what plug i need can n e one help
  21. umm its more round than square so id say round. 2001 motor
  22. im looking for the plug end for a stator. i bought a motor with it cut off maybe someone has a bad stator they are going to throw away they could cut the end off for me ? let me know
  23. u have air stryker carbs and they have 5 vent hoses apiece. they are kinda hard to rout under the motor. has n e one cut them all off at the bottom of the bowl? does n e gas ever come out of them and make a mess? any suggestions
