I´m replacing my clutch to my RZ 350 street bike and my OEM gasket was cut in several pieces.
I don´t have new one so can I replace it with "motor sealant" or something like that??
May sound stupid question but I need to know.
Thank you.
-Pasi S.
it may effect where the water pump gear meshes with the crank. i would just get a new one they are cheap....
aren't the rz 350s air cooled?
OK thanks guys!
Yes -the RZ 350 and RD 350 31K 1983-> models are water cooled (RZ USA and Japan, RD Europe).
I´ll try to find a new gasket. I know that they are sheap, but hard to find from anywhere near me.
If I can´t find it today I will but it back together with motor-sealant and look how it works.
The reason for this question was that I was thinking if the gasket holds the oil a little longer with the clutch when I´m turning to left. The gasket is so funky looking. ( hope you understund what I´m trying to tell here - HEH!)
-Pasi S.
OK! I found a good picture about new clutch gasket. I can´t see why I can not use motor-sealant for replacing it.
I called some local shops and they do not have new gasket for me.
-Pasi S.
i would just use rtv but if u think u need a gasket cut one out of a cereal box then add rtv to each side or u can go to auto zone and get a sheet of gasket material and cut it out. but IMO that gasket is so thin i dont see how that could effect anything.
the end of the shift shaft sits against the case if you don't use a gasket it gets in a bind....try it
You all have to realize Pasi S. is in Finland , no Autozones ,lol . I would try using Permatex non-hardening gasket sealer especially where rips (cuts) are . I think making a gasket would be last choice . It's not impossible , but it's a pains taking job , I've done it. Second choice would be RVT (silicon) , nice bead, let set little bit , set cover on ,start screws , but dont tighten , let set couple hours , then snug screws. Then when you get new gasket replace it. If this has to go through a translation program I hope you understand it . Let us know how it turns out.
the shift shaft always sits against the case thats what holds it in place
I put it back together with the black-oilproof-motor-sealant-I think it´s like RTV- silicon-something like that-thing! LOL!
It holds the oil in, so that´s enough for me.
Went for the test ride with it yesterday and it´s good. Gears and clutch is working like new.
-Pasi S.
(I can understund 99% of your english! 1% is when it "bogs" or "back fires"... HA ha!)
-Pasi S.
sorry i did not know that you do not speak english some times i use short hand when i typ and my spelling is bad
no kidding..but when you put the cover on with no gasket there is not enough clearance sometimes.
Edited by AWR
