yeahitsmine Posted June 8, 2010 Report Posted June 8, 2010 Hey guys im new to the forum but not knew to the banshee this is my forth banshee and i know im in love it is basically everything i wanted in a bike so now heres my problem I was enjoying my new shee today drifting around the corners and then my bike lock up. I thought it was the motor and then I started it up i couldnt move in first but i could move it in second now I have no neautral and cant find no other gears what could it be my friends Quote
SAVAGE420 Posted June 8, 2010 Report Posted June 8, 2010 First off Welcome man. First thing i would do is drain the coolant then flip the bike on its side (clutch facing up level) and pull the clutch cover off and check to see if the eccentric screw sheared off or if you bent your shift shaft, or maybe your shift star come loose or fell off and got jammed up. Also check to see if the basket is still intact and not broken as well as the gears behind it, basically look at everything in there to see if anything is bent, broken, really worn out or fell off. Worts case, it could be that you bent a shift fork or stripped some trans gears inside, you will need to split the cases to check. (not even a big deal though) But check the first things at the top first, proly something really easy so have a look see and check back. Quote
yeahitsmine Posted June 8, 2010 Author Report Posted June 8, 2010 First off Welcome man. First thing i would do is drain the coolant then flip the bike on its side (clutch facing up level) and pull the clutch cover off and check to see if the eccentric screw sheared off or if you bent your shift shaft, or maybe your shift star come loose or fell off and got jammed up. Also check to see if the basket is still intact and not broken as well as the gears behind it, basically look at everything in there to see if anything is bent, broken, really worn out or fell off. Worts case, it could be that you bent a shift fork or stripped some trans gears inside, you will need to split the cases to check. (not even a big deal though) But check the first things at the top first, proly something really easy so have a look see and check back. thanks for the response bro i will check that tomorrow might be a rookie question but how do I drain the atifreeze and what is a good antifreeze to put in the bike Quote
SAVAGE420 Posted June 8, 2010 Report Posted June 8, 2010 Just undo the clamp on the lower rad line near the clutch cover. Have a bucket ready though Just grab some prestone 50-/50 premixed stuff, its cheap to buy. If you want to change your trans oil, its a good time to do that also. But if you don't want too, flipping it on its side, all the trans fluid will go to the other side of the trans and you wont get it all over the place. But its cheap for a couple bottles of trans fluid though. Just don't over tighten the drain bolt when you tighten it up though . I always flip my bike on its side when im in the clutch side, MUCH easier on the back so you don't have to kneel on the ground or all hunched over and what not. Quote
bansheesandrider Posted June 8, 2010 Report Posted June 8, 2010 It sounds to me lioke you screwed up second gear, possibly welded it to the shaft. Follow Savage's advice as you will have to do all that anyway to get to the tranny, but I think you will be splitting the cases. Quote
yeahitsmine Posted June 8, 2010 Author Report Posted June 8, 2010 ] well i took the cover off and nothing looks broke stuff justs smells burnt the clutches look fried but could that be the reason the bike doesnt move in first but only in second Quote
yeahitsmine Posted June 9, 2010 Author Report Posted June 9, 2010 ] well i took the cover off and nothing looks broke stuff justs smells burnt the clutches look fried but could that be the reason the bike doesnt move in first but only in second heres some pics any advice is well appeciated is there something els I should remove to get a better look Quote
locogato11283 Posted June 9, 2010 Report Posted June 9, 2010 will the bike go into neutral? if not, you more than likely bent a shift fork and the cases will have to be split. i would drain the oil out of the cases and see if there are any parts. chances are if you bent a shift fork, there are some metal pieces that will run out when you drain the oil. Quote
baker Posted June 9, 2010 Report Posted June 9, 2010 well if it turns out ya need a tranny or tranny parts i got a complete tranny, forks everything ill sell ya, pm me if ya need parts. hopefully it dont come down to it but ya never know. pull the clutch basket off and check the gears. mine once broke the shift adjuster screw and locked it in between some teeth Quote
pondtunes Posted June 9, 2010 Report Posted June 9, 2010 Grab an electric impact and take that clutch basket and gear off.. Take a rag and put it between the crank gear and the gear that is behind the clutch and turn counterclockwise to put the gears in a bind. This will make removing that large nut that holds the clutch basket on much easier. Bend the tabs down on the lock washer holding the clutch basket nut on. Grab an electric impact and a huge socket, im thinking it was 32mm. Remove clutch basket nut. Take the rag off and the clutch basket should slide right off. Theres a large grooved bearing/sleeve behind it so don't drop it on the floor. then you should be able to see your shift star. If it looks like this then you'll need a new screw and a bottle of blue locktite. I had the exact same thing happen and mine turned out to be the screw holding the shift star on had come loose, backed out and pushed the shift fork off of the shift star. Now is a great time to do the shift star and or fork mod btw *Edit* One more note.. Your banshee transmission will NOT shift past second without the wheels turning! So if you find a problem, fix it and try to shift through the gears you'll need to spin the wheels or transmission to get it to move up past second. Quote
yeahitsmine Posted June 10, 2010 Author Report Posted June 10, 2010 thanks for the advice im gonna do that tomorrow i wish u would have told me about this sooner before I had took the motor off i will inform u thanks bro Quote
Koolguyson Posted June 10, 2010 Report Posted June 10, 2010 thanks for the advice im gonna do that tomorrow i wish u would have told me about this sooner before I had took the motor off i will inform u thanks bro Where you located? Maybe a local member can help you strip the motor down. Quote
SAVAGE420 Posted June 10, 2010 Report Posted June 10, 2010 thanks for the advice im gonna do that tomorrow i wish u would have told me about this sooner before I had took the motor off i will inform u thanks bro I said to check that and the rest in my first post bud! Quote
yeahitsmine Posted June 10, 2010 Author Report Posted June 10, 2010 Where you located? Maybe a local member can help you strip the motor down. Im in philadelphia pa Quote
yeahitsmine Posted June 10, 2010 Author Report Posted June 10, 2010 I said to check that and the rest in my first post bud! I didnt know that I had to remove the clutch basket I was just inspecting it with the cover off Quote
